- Feb 9, 2007
I have to get a pair of those Diamond rods for my SharpMaker, everyone raves about them..
To the GATCO fans posting here, a question:
Have any of you had any issues with blades moving/slipping inside the clamp? I've noticed that the inside faces of my clamp aren't quite flat (slightly convex), and can even see a slight 'turning up' of the contact face at the forward corners of the clamp, where it grips the blade spine.
Yes, I had this problem too... until I flattened the clamp faces with some wet/dry sandpaper and ten minutes of work.
I had to take off quite a bit of metal but the results made it worthwhile.
Stitchawl
On the one hand, it's good to know I wasn't alone with this. On the other hand, looks like I've got some sanding to do...
By the way, what grit sandpaper did you use? Did the sanding marks (if any) help provide a little more grip on the blade?
Thanks
Sorry... had to be about 15 years ago. I really haven't a clue what grit I used, but if I had to do it now I'd just rub the face against a 120 stone and be done with it. As I recall it was pretty soft metal.
I don't know that the sanding marks had any great effect on the grip, but the fact that the faces made full contact with the blade sure did! I rarely had any further problems except when trying to sharpen a very, very thick blade... I couldn't get the angle of the faces to match the angle of the blade. Other than that, they held tightly to all other knives, large and small.
Stitchawl
My style is impetuous. My defense is impregnable and I'm just ferocious.- Mike Tyson
I moved the clamp all the way back to the tang (it was up against the handle) so it could grip the 1/4" or so of flat available there. Was a challenge in setting it up, but in the end it worked out well...
Didn't that result in a noticable change in the angle between the heel and the tip?
cbw
