- Apr 12, 2009
I wouldn't flatten lansky stones, because they are used in a guided system removing a millimeter of stone could result in 2~3 degree change.
I mount the hone to the rod such that the base (working surface) of the hone is flush with the rod. In other words, I put the rod & hone on a flat surface with the honing surface down, and make sure the rod is laying flat on the surface. Then tighten the thumbscrew with the hone & rod laying flat on the surface in this manner. As long as this is so, it makes no difference how thick the hone is. The hone will always be aligned properly (and consistent with other hones used) for the desired angle setting.
