 - May 11, 1999
I just received a Gatco sharpening kit which is an obvious tribute to Lansky's rig, however
the Gatco seems to have several advantages over the Lansky which I wondered if anyone had any comments about:
1. there are more angles to choose from.
2. the hones are wider (more blade coverage and easier to hold) and have telescopic rods that are built into the end of the hones.
3. the storage box is of slightly better construction.
On the down side the front thumb screw is too small (for my hands anyway) to grip easily and the blade clamp doesn't have a hole in it to use it on a Lansky table clamp. Q: Has anyone tried to drill a hole in the Gatco clamp so that it can be used on the ingenious Lansky flip-over table clamp?
Now the Lansky pros/cons:
1.the all-aluminum clamp seems built to last a lifetime. I'm a little worried about the plastic parts used in the Gatco clamp.
2. obviously, the way the clamp can be flipped over so easily on their table stand is a real bonus.
3. the rig is smaller and therefore better suited to field use.
I'm eager for your replies.
Jason F.
Jason F.
