- Feb 23, 2021
Hey all, I have a unicorn set up for grabs while the Custom EVO I'm after is still available. I will not be separating these and I will not take any trades. Grab em now if you're interested as you'll most likely never see another set like this!
- Large Sebenza Regular Serrated w/ Swedge and Blue Double Lugs
- Small Sebenza Regular Serrated w/ Swedge and Double Blue Lugs
Both are in fantastic condition with almost no wear for their age. There's a couple pin hole size spots on the blade on both knifes which look to be corrosion marks, which seems very common with these S30V blades. Both will come with form fit CRK slip sheaths.
Other than that, there's nothing wrong with them aside from maybe some minor wear on the handle edges from being in and out of a slip sheath. No blade scratches, the only thing is maybe a very light mark here or there on the polished swedge.
The large was sharpened once by CRK I believe, but appears to have full life left in it as it measured tip to heel and tip to bottom the same before and after sending it in (I used calipers to check this because I'm OCD). Funny enough, it has larger blade measurements than a factory replacement Large Regular blade I got a while back. Comes with a reissued card as well as everything else in the picture below.
The small still has a razor sharp original edge. It comes with everything included originally as seen below.
$old Shipped and Insured for the Pair
