Do you have any other blades already in your kit? It makes a big difference.
This is a big factor, one of many, do you have a fixed blade at all? Weight, length, purpose, and area of operation are some of the other considerations. Does it need to fit in your pack?
If you're in a jungle, maybe you need a long thin machete, where a northern hardwood forest would require lots of wood prep, then an axe is king.
Also, is this a weapon or just a tool? If it's a weapon, a tomahawk with a quick draw sheath that can also be worn on you is a great choice.(after gun goes "click")
You can get an Ontario Machete, either 12" or 18", plus a sheath, and even Baryonyx Knive's upgraded convex edge. The heavy duty machetes from Ontario are 1/8" thick, and can take a serious beating. They can chop wood, baton, and do machete chores. The 18" is a little bit heavy for doing lots of light work, you have to stop that swing every time. OTOH, that mass helps to chop wood, if that's the chore.
http://www.baryonyxknife.com/18cumawgr.html
http://www.baryonyxknife.com/12cumawgr.html
These are a great value, and a great starting point for a more "tuned" machete. Bark River, TOPS Knives, and Andy Roy of Fiddleback Forge have all done a modified Ontario machete. Many others have added wood or micarta handle scales to theirs, I put some Hickory on my 12" Cutlass machete.
The Fiddleback's are Imacasa and not Ontario.
I would second the 12" from Baryonyx. I've gotten a couple of "special grades" from him and he does good work. Basically he fixes the edge, squares a part of the spine, and trues up the scales to the tang.
I know, I have a 14". BUT, Andy did a modified Ontario at least once, pics are on his website, or used to be.
