Large engraved hunter in CPM S30V and Cocobolo
Feedback: +43 / =0 / -0
This is heavy and hefty hunting knife. The blade is a bit less than 5" long. 1/1-2" wide and 3/16+ thick. It is evenly tapered to the blade tip. SPM S30V stainless Steel blade was heat treated by Paul Bos Heat Treating to guaranteed 60HRC. Hand finished to 800 grit. The knife is ~ 9-1/2 OAL.
The guard is 416 Stainless Steel. I hand engraved it with the unique floral design. The background is removed and stippled to bring up the 3D effect.
The scales are Cocobolo, tightly fitted in the dovetailed guard, glued with epoxy and riveted with stainless tubular rivets. The wood was vacuum treated and polished.
This knife comes with the leather sheath. The sheath was hand stitched, dyed and treated with the Saddle Oil.
The sheath has an oversized belt loop.
Closed for repost
This knife has 4-1/2" X 1" X 1/8" blade made of CPM S30V. Heat treated by Paul Bos Heat Treating to 60HRC.
The blade was hand finished to 800 grit and has flat bevels.
The guard is 416 Stainless Steel. I hand engraved unique design in tribal style.
The scales are Sheoak wood, dyed and deep vacuum treated. It is NOT dishwasher safe though.
The tubular rivets are 316 Stainless Steel.
The knife comes with the pouch style leather sheath. I hand stitched it, dyed and treated with the Saddle Oil.
SOLD
Looks awesome. Didn't realize it but I'm only about 50 miles from you if Austin,MN is your location.
