LARGE lot of paintball gear
Feedback: +5 / =0 / -0
This one pains me, but money's tight, and it's got to go.
This is my entire collection of paintball gear. I played mostly woodsball, but did some tourny stuff in college as well. This rig was AWESOME out in the woods. Every single piece of gear had woodsball in mind. Stealth and accuracy was my goal. I bought the best gear I could to get there.
So. We have:
*Deep breath*
'02 WGP Autococker
WGP Blade Trigger (2 mm pull. Basically a hair trigger)
Dye Sticky Grips
Gas-thru Stock
Q-loader system (this spirals paintballs up from underneath so you don't have the huge hopper up top getting shot all the time)
Empire Revolver Barrel System (this system has barrel sleeves you slide in that match to different diameter paintballs to ensure you have a perfect fit)
Sure Shot Red Dot Sight
Stock Autococker Barrel
SmartParts All American Barrel
Pure Energy 72cu 3000 PSI High Pressure Tank
Extreme Rage Powered Hopper
Standard Hopper
Dye Barrel Condom
2XS Armored Gloves
Chest Armor
Rip Squeegie
Plunge Squeegie Set
Dye Head Wrap
Swat Hat
Swat Balaclava
Remote Tank Hose and Hookup
Proto Axis Mask
JT Mask w/ Smoke Lens and Spikes
JT Mask w/ Ghillie camo
Tactical Vest that holds air tank, 6 tubes, and a bunch of stuff in the front pockets
Spec Ops Fusion Camo Paintball Pants (size L)
Spec Ops Fusion Camo Paintball Jersey (size L)
Custom Case to hold the gun and tank
Like I said, I've built this for accurate stealthy woodsball. With the Q-hopper underneath, you only need to expose the tip of the barrel. Put the red dot on them, and splat. This gun is completely manual, no batteries to die. I loved this gun, and took extremely good care of it.
I haven't used this gear in about 3 years. I can assure you that it was in flawless working condition then. It will need a lubing (lube included), and probably new O-rings all around, which will cost you like $3 or so.
I can't even begin to add up the money I put into this. WELL in excess of $1500. The gun alone was $400. $150 for the blade kit, $100 for the Spec Ops clothes, $130 for the barrel system, $150 for the masks, $150 for the q-loader, on and on and on. I need to move it, and I don't want to break it up, so I'm letting the whole smash go for $600 -> $500 -> $400 paypal'd and shipped CONUS
more pics to come.
