Cliff Stamp
BANNED
- Oct 5, 1998
After recently buying a Cold Steel Twistmaster I went looking for an Opinel which is what the Twistmaster is based on, or at the very least heavily influenced the design. I had used Opinels in the past and recall being very impressed with the cutting ability. I was curious just how they would compare to the modern high end version of the same blade. Lee Valley sells them, and they are quite cheap so I picked up a few. There was no difference among the ones I received fit and finish wise and I kept one large one, and gave the others away to a few friends to get their impressions. A shot of the Opinel alongside the large drop point Twistmaster :
http://www.physics.mun.ca/~sstamp/images/opinel.jpg
The only real problem was that the edge while having a suitable geometry for a fine cutting knife, was not finished well. Under magnification revealed basically a rough shaping with no polish - it was very blunt NIB. However considering the geometry was right where I would want it, the fact that I had to sharpen it was only a minor problem. To be specific the blade stock is ~3/32 and the primary grind was full flat at about ~3.2 degrees. The edge bevel was barely existent, the blade was only 0.002-0.004" thick behind the bevel which was just wide enough to see. I cleaned up the edge on some sandpaper, less than 100 passes including the final buffing. It polished to a fine shaving edge. If you are using a rod based system, you will need to go very light, as some experimentation showed that the edge tends to roll rather easily.
Basically we have a knife ground out of thin blade stock with a near optimal grind for high performance deep cuts. For awhile I just used it for all manner of cutting. The work ranged from paper and cardboard cutting, to fine and rough wood work, as well as significant amounts of food preparation on meats and vegetables. The blade excelled at all tasks. It easily for example out cut the Twistmaster from Cold Steel, and in fact is pretty much the highest performing blade in that class I have ever used - which is no surprise as the blade geometry is about as extreme as you can get, with one minor modification which I'll mention later.
Does it have any drawbacks? Well yes, the rather obvious one is that the durability is rather low. It would not be a blade to be used for any kind of heavy impact work nor prying and that sort of thing. Along those lines the lock is also rather weak. For example while it can be used to lock the blade in the handle which is a nice feature, a couple of times I had it locked and forgot to unlock it and just went ahead and opened the blade popping the locking ring off. It just pops back on as its elastic. Experimenting with trying to force the blade closed when locked didn't leave me impressed with its raw strength either. Basically I would view this just as a light use folder only, heavy dynamic cutting would be dangerous.
The handle is just wood, and quite slick. The Kraton grip on the Twistmaster for example is far more secure. However considering the type of use that this knife will typically get, this doesn't actually stand out as much of a functional disadvantage. For even heavy work it is ergonomic, no discomfort. I do have a friend however who uses a large Opinel as a fillet knife and he had to have the handle checkered to allow it to be functional when handling a large amount of cod in a hurry. As well, this isn't a handle that you would want to be pounding on or with, but again considering the type of use that the blade is intended for, I don't see this as a problem.
The other big question is in regards to the edge holding. From what I have read the steel is ~1075 and the RC hardness is only moderate. However even with a low edge retention, considering that the cutting performance is so high, the lifetime of the cutting ability is very long, unless you are cutting very abrasive materials. It holds up very well on standard hemp testing, more on that below. And of course it grinds very easily. The combination of a very acute and thin edge with an easily machinable steel allows the blade to be restored very easily on even soft natural hones. The only real problem is that it will burr easily because it is soft.
Some specific tests on cutting ability on 3/8" hemp :
Fine finish, stropped, push cut : 12.5 +/- 0.3 lbs
Fine finish, ceramic, slice : 10.5 +/- 0.5 lbs
Medium finish, 600 DMT, slice : 9.5 +/- 0.5 lbs
The slicing cuts were done with a 22 degree micro bevel, about 0.1mm wide. This is just the result of a few passes on a fine ceramic and 600 DMT rod, fixed in a rod type system. The push cutting was done after stropping and had no micro bevel so it was slightly convex starting from about 8-10 degrees and ending at 12-14 degrees near the edge.
This level of cutting ability really needs to be experienced in order to be understood. With the amount of force under 10 lbs, slices through the hemp seem to be parting the rope like water. For comparison, this is far above the ability of the Twistmaster which takes 25 +/- 2 lbs to push cut the hemp with the same stropped finish. I have seen knives that required 250+ lbs to push cut the same rope.
Trying out some hardwood dowel revealed even more impressive performance. The Opinel would cut a point off of a 1" hard wood dowel in less than two slices (~1.5) . The best I had seen previously was ~5 cuts with the MEUK from Blade/Caffrey. For reference the Twistmaster from Cold Steel takes ~12 slices.
Back to edge holding, I did some work on 3/8" hemp. Slices were done over 2" of blade length on a pine block.
With a fine ceramic finish (22 degree micro bevel), the initial performance was ~80 g on the thread, 0.28 cm on the poly, and ~11 lbs on the hemp. After 62 cuts the blade took over 4 cm to cut through 1/4" poly under a 1000 g load, over 300 g to cut light thread, and needed ~20 lbs to slice through the hemp. The blade was well past shaving sharp and fails to be able to do any fine work well. It responds very well to steeling, and just a few passes on a smooth steel returns it to shaving sharp.
When the cutting was ran again with the fine DMT finish (22 degree micro bevel). The initial performance now was 153 g on the thread, 0.5 cm on the poly, and ~10 lbs on the hemp. It now took 126 cuts on the hemp to get the same increase in force on the thread and the hemp cutting, and 254 cuts to see the same loss of aggression on the poly. The blade still responded to steeling well after the 254 cuts, returning to shaving sharp and back to near optimal levels of cutting ability on the thread, poly and hemp.
[the steeled edge blunts significantly quicker than the original edge for everything not just this knife]
Finally, in regards to corrosion resistance, this is just a plain carbon steel and thus will patina quite quickly and as well develop rust spots if you are not careful. However over time as the patina darkens, the orange rust will happen less frequently.
Overall I would prefer this over the Twistmaster it is a more coherent design. The Twistmaster is more robust, but not so much that I would use it for really heavy cutting and the higher cutting ability of the Opinel would have be reach for it every time for light use. The only changes I would want would be to put a hollow relief over the primary flat grind, and radically increase the RC on the steel. M2 at say ~64 RC would be very nice, but even 1095 at that RC would be a very solid.
Left to do is some edge retention work on some abrasive material as this is likely a weak point. I also have to figure out a way to put the results of the edge retention in a sensible format as the blunting rate is not linear as thus it is easily misinterpreted.
Ref :
http://www.bladeforums.com/forums/showthread.php?s=&threadid=175216
-Cliff
Ref :
-Cliff
