Large Opinel
Yesterday, I did some rope cutting on the Opinel with the edge profile as indicated in the above. I was expecting slices at less than 10 lbs initially, and to at least reach 500 cuts before the force exceeded 20 lbs. However it took ~18 lbs to make a cut at the start, and after about 50 or so cuts the force was at ~20 lbs. I tried the same sharpening process, only slower this time, on a couple of other knives and the sharpness was horrible on each of them. Specifically, while you could get a strong bite, it required a huge amount of force. In retrospect I should have expected this as I noticed this connection awhile ago. In short, there is a practical limit to the aggression you can get with coarse edges as if you go too rough the amount of force required is far too much. The best result I have seen so far was from a slightly worn 100 grit AO belt. I intend to polish the primary on the Opinel and do some cutting with it at various finer finishes.
Chad :
... stropping resulted in an over polished edge, so that the gains in push cutting were too drastically offset by the loss in slicing ability.
Plain leather and canvas loaded with paste can align without generating the level of burr of a smooth steel and without removing the micro-teeth as buffing compounds will.
[stropping]
... even a small amount adds a slight convexity to the edge (rounding) which results in a loss of acuteness.
You can avoid this by using a high end strop. It should be pressed leather and thus very smooth and dense. Most modern cheap strops are soft and deform easily.
[710]
My main problem with that knife isn't because of what it is specifically, but what it could be. M2 is a very wear resistant steel capable of getting to 64-66 RC and has a very fine grain. It would be near ideal for an optimal cutting knife focused on light use work and high edge retention (Opinel). The 710 is, I have no doubt, a very solid work knife capable of handling a broad range of tasks, however for that role, something simpler like A2 or even 52100 would have allowed the same performance without the drawbacks of heat treating and machining M2.
In regards to the edge profile, since you are not chopping, you can go really thin and thus allow a much more obtuse edge (and therefore durability) at the same level of cutting ability. The 52100-MEUK I have has an edge of 20+ degrees but will easily out cut knives with much more acute edges because its edge is much thinner (0.005"). I can use it roughly (like splitting knotty wood) without harm. Last time I checked Benchmade was still running their edges quite thick and thus not what I would want performance wise, even if I spent the time to thin it out, which isn't attractive considering the price point. If one comes up cheap on the secondary market I'd look at it seriously, probably re-profiling it bring the main bevel up and down, probably going full convex, and in any event, making the edge thinner.
As well, sabre-grinds on folders really boggle me, and I have concerns about the axis lock after hearing multiple reports of problems. Yes you can just send it back for single spring failures, but since I am in Canada that isn't as easy as it sounds and it is obviously not as robust as simpler designs like lockbacks and the Compression lock. I have settled on the Opinel for a light use folder and am still looking for a more serious work piece. It would be nice if Spyderco would put out a Compression lock folder with a 3/16" blade, full flat grind, right down to at least 0.01" with a 15 degree edge made out of a sensible tool steel, barring that, S30V.
When I want a higher level of corrosion resistance I leave the 710HS and Opinel and substitute a CRK Sebenza. In either case I get a high performance blade and a very strong, secure lock.
The Sebenza does have a very high performance cutting profile, but I have ergonomic and security problems with frame locks, similar to liner locks. Right now I prefer lock backs and compression locks. As well, with a heavy use folder, I would not want a high hollow grind for durability reasons.
... I have found that a multi-knife system is better, where each knife is optimized (or nearly so) for specific tasks.....
It is the ideal system as then you can also optimize the handle as well as the blade for the given tasks. One of the other reasons that I am really leaning towards multi's as of late is that they are more traditional and don't give off the "weapon" vibe that one handed openers do.
[full size Spyderco Calypso]
I have used the small one extensively and would mirror your comments exactly. Last time I seen it the clip had broken off, taking a huge chunk out of the Micarta, beats me how that was done, same guy mauled the clip on a SOG X-Ray Vision. The lock was still rock solid. Mine was AUS-8 which I found rolled too easily, the VG-10 one should be harder and a very nice upgrade. I which they would come out with a truly optimized one, say ATS-34 or BG-42 at 62-64 RC with a very thin edge and acute angle and promote it as a totally optimized pure light use cutting tool.
In regards to steeling (burnishing): I find that a fine ceramic rod provides the best means for me to do so, it realigns the edge and removes a small amount of steel and exposes fresh carbides.
My perspective is pretty much the same. For aggressive edges, the first thing I try is some stropping on plain leather or canvas and if that doesn't work a few passes on a smooth steel followed by a couple of strokes on a diamond or ceramic rod to remove the burr and rounded carbides. For polished edges I just strop on CrO.
[Ontario machetes]
... while cutting some thicker branches I experienced blow out in the edge (visible chunks of metal being lost), this is normally the opposite of what I would expect to see as the 1095 is heat treated very soft and I'd expect to see denting and impaction, not metal loss.
I saw the exact same failure with two of them. Very odd when they show high flexibility and in general very durable edges so I don't see fracture growth under impact as being likely. I would guess it is probably a heat treat problem resulting in chains of segregated carbides or impurity clustering at grain boundaries. It could also be just localized problems in the steel, maybe they are just buying low grade. Considering the prices, its not that great of a leap to assume they are cutting costs somewhere.
3. I think that edge alignment is THE most critical factor in cutting performance.
Yes, exactly. This is one of the greatest misconceptions about cutting performance, as people often comment that "shaving edges" as they are not aggressive. You can get really aggressive edges to shave if they are sharpened with care. I think Joe Talmadge was one of the first people to clearly illustrate this, as most people just assume that coarse edges can't shave. I fluked into it a few times by accident before I realized what was going on as I had just believed the common perception. Improper edge alignment is probably the single biggest problem with NIB edges. Most of them can see performance gains of ~100% with just a couple of passes on a rod or some stropping to align the edge and remove the burr.
When I see (or feel in most cases) chipping it is usually very localized damage, but when I see a deformed edge a much larger area is usually in question.
Yes, the only other consideration here is the depth of damage and propagation. Under impacts for example, chips are much more likely to spread than dents, this is of course only relevant for large chopping knives.
GREENJACKET :
I'll live with a little loss of steel, and prefer a little loss every time rather than a break off of a switching burr as can be found from hard smooth steeling.
Yes, the extended lifetime is a large advantage as is the fact that the edge is stable unlike steeled edges which will relax to being blunt over time even without any use.
For machete sized blades, I now use DMT diafolds as these blades invariably sustain damage to the point you may as well loose some metal every time you strop or sharpen.
Yes, I also under cut the edges on my machetes as I don't really care if the edges does get dinged up, and the increase in cutting ability is worth it. For a high end blade you don't want to do this as you will wear it out fast, but for a $10 who cares. Get the best performance you can and buy a new one every now and again.
if you are generating that amount of heat to melt the plastic, aren't you throwing the heat treatment too?
I doubt it, you would have to go above the tempering temperature and I was holding onto the blade during the process.
Cold Steel has tried to improve things by making a tougher knife, because Cold Steel knives have to be. Unfortunately this looses the whole point of the opinel style.
Yes, this happens often when people try to "fix" something without really understanding the intention of the design.
think opinels bend rather than break. I think I can remember seeing an opinel with a buckled point It would be interesting to know if the Cold Steel snapped or bent also.
I have broken a couple CS knives, and they will snap suddenly, the Twistmaster is quite thin though so I expect it to flex quite a bit before it snaps. The blade mount, since its only plastic, may in fact just be broken apart before the blade is over stressed.
Cliff, off topic what experiance do you have of Strider Knives? e-me.
Will do.
-Cliff
RE: 40 grit edge finish.
An edge that rough is like a "hungry" saw, it will take a lot of effort to pull the teeth through, a natural consequence of the amount of material they are removing with each stroke. At en edge finish that rough, I'd expect to see a large amount of tear out of the metal from the edge when cutting anything of substance and some snagging when cutting cloth.
I agree that there is a limit to the aggressiveness that you can imaprt an edge and still be benificial. There may be larger "micro-serrations" but they are in disorganized state, imagine small saw teeh jutting out all over the edge surface, ot just along the cutting plane. This results in higher degrees of friction, so you have to use more force to make the same slice, and unless the steel is a very strong one, the tearouts will only increase the amount of jagged micro-bits of steel, further increasing the amount of force needed. There will be exceptions:
Cutting through cardboard, especially if it has lots of mineral dust inclusions, may polish the edge, decreasing the amount of friction, and thus the amount of force needed with each cut (to a finite limit). This is a counter-intuative situation, where you would usually see rapid dulling with a knife that did not have as course an edge.
But the above observation are based on a very small amount of work with very course edges, and never anything close to 40 grit....
Re Strops:
The strops I am using now do readily deform, and I can see where this would add the convexity where a firmer leather would not. I try to compensate for this by having the strop supported by a wood base as I have found that slack stropping results in a very rounded edge. A problem that I foresee with a harder leather is that the stropping angle would become much more critical, as you would no longer have the leather deforming to "automaticly" create an even and consistent angle as you do with softer leather. BTW I made my strops out of old pieces of saddle leather and old duty belts (they must have shrunk because they stopped fitting me, must be due to the humidity in my locker :) :) ) I will have to invest in a proper strop soon....
Re BM 710HS:
I have found the M2 to be excellent, I believe BM is running it over 62RC, and it does not chip out and is actually quite easy to sharpen. As you note, it is very fine grained and takes a very keen edge.
While I would prefer a full flat grind, the 710's sabre grind is quite high, and does provide a degree of added strength. Because the stock is quite thin (it is only about 1/32" thicker than the Opinel) the geometery imparted by the high sabre grind is really quite good. With the edge reprofiled to a proper angle it will easily outslice my Sebenza in fiberous materials. The Sebenza does pull ahead in push cutting non binding media however. This is about what I would expect given the grinds and blade shapes (flat recurve vs. a thin, high hollow grind).
The NIB edge is worthless however. If you don't reprofile the edge, you would be very dissapointed in the performance. Joe Talmadge's claims of 700% improvement over stock is very believable (and I was skeptical of the claim until I had reprofiled mine).
I would find a 3/16" folder to be far too thick unless it had a blade width of over two inches or a very deep, very high hollow grind. While a blade that thick would offer lots of strength (especially in a high grade tool or powdered metal steel), it would really not meet my needs for the roles I expect a folder to play. Basicly if I am going to carry that much steel in a folder, it would be for some heavy work (high stress tasks), where I would want the additional size, strength, ergonomics and leverage of a fixed blade knife. Of course, there are times when you could carry a folder and not a fixed blade so the argument goes both ways....
I think, in general, I prefer folding knives as tools where light to medium stress loads will be encountered and high levels of cutting efficiency are desired.
I agree and that is one of the reasons I always carry a SAK and multi-tool, the other reason being there very high utility value. BTW I keep the blades on my SAKs [including the swisstool] at a high polish (ultrafine ceramic) and my Leathermen (I assume the plural) blades at a DMT extra course.
Re Calypso:
The vg-10 is a great steel, and I prefer it to the AUS8 of the jr, There are however advantages (and disadvantages to both), while the AUS8 rolls easier it is finer grained and takes a keener edge at a high polish, optimizing it for push cutting, while the more highly alloyed VG10 is harder (thus less likely to roll) it is also courser grained and more optimized for slicing (assuming the same level of edge finish, wish is a strong enough factor to dominate over the grain structure of the steel imho)
Re: Sebenza
While I can see the ergonomic problems as a factor (as they are highly individualized), I find the framelock to be a very strong lock, problems of failure under stress would seem to be the lock jamming the blade open, not the lock failing causing the knife to close. This seems to be an ideal set up for a heavy (for folders) use lock......
While I can understand your concern about the hollow grind, you have to keep in mind the strength of BG42 at 62-63 RC. While the blade may fail before the lock, I think that is the proper order of things, after all if the blade fails the risk of injury is likely much lower than the lock failing. But agin that could be argued both ways....
Re: Ontario Machete:
I though of heat treat as the likely culprit at first too, but the problem did not occur until after the blades had been steeled extensively. While ther may have been some inclusions in the brush, I did not see any (and I looked). Saplings and branches of this size had been chopped through earlier (pre-burninshing) with out failure....
Re MEUK:
I agree that it is a very nice design for a medium use knife.
The handle allows for excellent security and is very comfortable. The blade is nicely shaped and evenly ground, and the Kydex sheath is top notch.
I have not used mine to an extensive degree, I did some light work with it yesterday cutting heavy cardboard and some light wood work (a little whiitling while I watched my daughter play at the park):
Mine is 1095. I am running it at a 40 degree edge, so I am not seeing quite the performance figures you are. I usually start a knife in this class at 40 degrees and then work my way down, getting a feel for the increase in performance of the edge and the strength of the steel. I stop when I begin to see light damage in medium stress tasks. If I start to see chipping I increase the edge angle a couple degrees until I find the best comprimise between strength and cutting efficiency, looking for the thinnest edge possible that won't get damaged by medium stress work. I accept the risk of damage during high strength work and would rather have the increae in performance that comes from a thin edge (for this class knife). My general intuition tells me this knife will probably work best at a 30 degree edge (which works out well since it is a no brainer on a spyderco 204). This is thicker than you are running yours, but there is a different heat treat and steel involved.
Mine is a flat grind not a hollow sabre (into a convex)like yours as well so there may be a difference in performance based on the grinds as well. Marion Poff used both our knives (I got mione from him) so if there are any major differnces between the two, maybe he can tell us.
My one concern about the knife is that if there are any failures I don't know if Allen Blade will stand behind his work. He used to offer a good warrranty and refinish policy, now I don't even know if he is making knives, where he lives, or if he is even trustworthy anymore, but that is another topic that has already been overkilled....
BTW Cliff, we have to stop agreeing with each other. People may start to think I am just another one of yours and Jerry Busse's multiple personality disorder.......
Stay sharp,
Chad
After reading all this great stuff on the Opinel, I went out and got another one just to play with (how can you beat this knife for only $11 at a retail store?).
I started by re-profiling to 30 degrees inclusive (15 degree bevel). My Sharpmaker doesn't make going lower than that very easy. :(
Anyway, the knife would not scrape hair from the store. I spent about two hours reprofiling, honing, not getting the right alignment, rehoning, etc.
After an hour I was able to shave easily, but the burr starting getting so small I could no longer feel it with my fingernail. I could, however, tell that it was there by the difference in shaving performance between the two sides of the blade.
So I switched to using my lighted 30X magnifier. It is amazing what a magnifier will tell you that nothing else will. There was the wire burr, standing up like a mountain along the edge, along with other micro-deformations.
I kept at it, making the blade angle very obtuse to grind off the burr, then acute again to resume profiling.
By this time, the knife not only shaves, but at a <5 degree acute angle it makes hair scatter in large areas. I mean, I place the knife on my arm, and *very* gently move it. Almost magically, light patches appear on my arm. It takes me a moment to realize it's because a whole bunch of hairs (about ten strands) just jumped off my arm all at once. But still, the burr was there.
It took a while longer before the edge started looking really nice under magnification. Clean, smooth bevel, trailing off at a straight line. It's still not straight along the whole blade, though.
Then I pulled out my bright light, and shone it on the edge. It is even MORE amazing what a bright light will show you, on a truly keen edge. Like one of those secret decoder rings, the areas of deformation showed up as bright stretches along the edge. I have about 3 cm of perfect edge, and 5 cm of deformed edge. I'll head back to the stone tomorrow to do more focused honing.
But now hair disappears at 1-3 degrees of angle. I lay the blade flat on my arm, on the softest hairs (those on the underside of my arm), and hover the blade along. The hairs disappear, without my being able to feel it happen. Since it's able to do this on both sides equally well, I think I'm getting close to perfection...
Cliff: After getting a blade such a state, what would you recommend to then increase its slicing performance, without weakening the edge too much? I'm thinking about two gentle swipes on the medium stones at <20 degrees, just to give it a tad more bite. What would you recommend?
chad234 :
Yes, I expected this from previous work, however I still don't quite understand why it failed so badly. The aggression wasn't even there when I used a large amount of force. Under magnification the 40 grit AO finish was similar to the 100 grit AO finish just deeper, and the 100 grit AO finish worked well on the SOG Seal and MPK-A2 from Mission. The SOG started off at ~12 lbs on a slice, and ran for ~250 cuts before hitting 20 lbs (more on this in the second part of the "SEALS" testing). I think it had to do with the actual faces of the micro-teeth formed. I need to get a decent stereo microscope with digital capabilities to check these things out. Maybe it has to do with the ZO abrasive. I plan on trying it with a coarser AO abrasive as well. The other factor was the the 100 grit finish was applied with a belt sander while I did the 40 grit finish by hand. It could be that the force wasn't enough to get a clean cut by hand.
Cutting through cardboard, especially if it has lots of mineral dust inclusions, may polish the edge ...
Yes, I noticed this awhile back with hemp rope. It was really obvious with a MPK-Ti with the edge left filed. You could see the sides of the edge getting burnished smooth. I wonder how this influences testing such as CATRA does where the cuts are so controlled that this side polishing is very regular.
Yes, this is an excellent point. It is a trade off, the more you want to eliminate curvature the more you are going to have to get some angle control. At an extreme of course, you just "strop" with an 8000 grit waterstone.
[M2]
That definitely turns it up a lot, for some reason I was thinking of it as 59-60 which in reality often means much lower.
Yes, for a decent level of cutting ability, but I have the Opinel for that. The heavy-duty folder is more of a scraper, poker, hacker type tool, which ideally could also be used for baton work.
This is starting to get pretty silly as I do nearly the exact same thing. The SAK blades generally get used for finer work, as they are far more comfortable (Rucksack), and have a higher performance geometry. The Leatherman Supertool blades get used for rougher work a lot of it is scraping and cutting dirty and used materials.
[frame lock]
... problems of failure under stress would seem to be the lock jamming the blade open, not the lock failing causing the knife to close.
The jamming is one of the key problems. I have only handled one, but for heavy use could mash the lock so tight that I had to pry it open with something else. In regards to failure, there are cases of torques causing release as well as gripping tightly in the off hand. The ergonomic factor is a heavy one as well, as for heavy use it becomes more of a problem. All that being said, it is still one hell of a folder and I would easily put it above many others on the market, production and custom. Same for the one-piece line.
Yes, the raw strength though the main body of the blade would be quite high indeed. The failures I am concerned about are mainly blowing out a piece of the edge, again this isn't just strictly cutting, but prying, scraping, etc. .
... the problem did not occur until after the blades had been steeled extensively.
Steeling will weaken the blade through fatigue, however on first pass I would assume the damage would be restricted to the steeling depth, well below 1mm. I have seen failures exactly like that. For example when I chopped on some chicken bones with my BM after just steeling it for a very long time (months), the edge rippled. After a fresh sharpening, it chewed up the bones (and harder ones) with no problems. Upon further consideration, maybe what happened is that the steeled edge developed cracks and since they were never removed with honing they kept propagating up the blade, intersecting and causing larger scale problem. That is an interesting effect which I never really considered.
If I start to see chipping I increase the edge angle a couple degrees until I find the best compromise between strength and cutting efficiency, looking for the thinnest edge possible that won't get damaged by medium stress work.
Yes, I am the same, and like you noted will under cut the edge on most light use ones and put up with the occasional bit of damage to get an overall higher level of cutting ability. I often go the other way in regards to edge angle as sometimes I will just hog off a lot of metal on a grinder / sander and then work back up, generally though this is on knives that are just getting reviewed and not on personal carry as it can cause significant waste.
... yours and Jerry Busse's multiple personality disorder.......
He has the disorder, I am just a figment of his imagination. Its a pretty secure setup as its not likely anyone would ever come here to verify existence. We got let up on snow lately and just get freezing rain - excellent, that's much better. Am I correct in assuming we still have a sun?
JohnW :
I spent about two hours re-profiling, honing, not getting the right alignment, rehoning, etc.
That is a really long time. One of the key problems with poorly NIB sharpened blades was pointed out by Jimbo on his web pages when he noted that small hones can take quite a while to remove such problems, and to speed the process up you want to work on the edge evenly with a large area, he suggests sandpaper. What I do if the edge looks really bad (has a dip for example), is rather radical. I take a really coarse hone and turn it on its side and then place the blade edge first into the hone and do a couple of passes along the entire length following the curvature. This will even out the edge and remove all the damaged metal. You will now have a fair bit of metal to be removed to get an edge, however on the positive you will be working with fresh strong metal, and a consistent edge geometry.
In regards to the Opinel its biggest problem is that the steel is so soft. A common perception is that this raises "sharpenability", however while it does it raise ease of rough stock removal, i.e., shaping, sharpening is whole other process. Really soft steels are horrible to get high quality edges because they can't resist deformation well and thus the abrasives can't cleanly cut into them and just tend to mash them around. As you noted you have to go really light with rod based systems on the Opinel or you will just burr it. You need to keep the hones really clean, as if they load up at all the cutting ability goes down and the burr comes right back. It is easier with diamond abrasives, and easier with a wider abrasive which will decrease the pressure. Finish on a strop loaded with CrO for the ultimate polish.
You sure picked the right blade to achieve it. With a high polish, due to the extreme nature of the geometry, the push cutting ability will be very high and thus many tasks that other blades find very difficult, this one will do very easily. Nice comments on checking the edge by various methods. The amount of frustration that many people have with sharpening would be vastly reduced if people would check the edge under magnification and thus figure out the nature of the problem. Only when you do this can you get a solution.
... what would you recommend to then increase its slicing performance, without weakening the edge too much? I'm thinking about two gentle swipes on the medium stones at <20 degrees, just to give it a tad more bite.
That is pretty much exactly what I would do, except I would use a fine diamond rod as it will be a bit more aggressive at light pressure than a ceramic and thus tend not to burr the edge. A couple of strokes is all that is necessary, just as you suggest. You can check this under magnification and it should generate a small (0.1mm or less) micro bevel. Note if this is the end goal then you really don't need to do much pre-polishing. Awhile ago I tested how the edge as a whole effected the cutting ability and edge retention by doing runs with the bevel set at a 1000 g waterstone finish, 4000 g waterstone finish, and CrO finish, and then applying a fine DMT micro-bevel. I could see no difference in cutting ability and edge retention. As Chad noted, if you check under magnification you will see that the cutting will actually polish the sides of the edge. It is critical though that before you apply the micro-bevel that the edge not have any large problems, a small burr is fine as the rod will just cut that off, but there can't be any deep irregularities. You can again check this under magnification as you should have a uniform tooth pattern all along the edge. A few test cuts will allow you to check this as well as the blade should cut smoothly along the entire length.
-Cliff
Cliff re BM M2:
This is from Benchmade's FAQ:
" M2 is a fine-grained molybdenum/tungsten high-speed tool steel. It is typically composed of:
Carbon- .85%
Manganese- .35%
Phosphorus- .025%
Sulfur- .025%
Chromium- 4.0%
Silicon-.04%
Nickel- .30%
Vanadium- 2.2%
Molybdenum- 5.5%
Tungsten- 6.5%
M2 is a very tough grade of steel most commonly found in drill bits and end mills. The high amounts of vanadium, molybdenum and tungsten make it very resistant to wear and very difficult to grind. At a Rockwell hardness of 62HRC it exhibits extreme toughness, with no signs of brittleness, and edge retention that is superior to most other blade materials. The only drawback to this material, other than being difficult to work with, is the fact that since it has only a small amount of chrome it will rust unless properly cared for. Since most knives do not, or cannot, receive this proper care our knives with M2 blades will only be available with our BT2 coating."
I think BM is treating the M2 to an honest 62RC, and because it is a high grade tool steel it is much more impact resistant than a stainless stell like ATS34 is at this hardness, This allows for an edge that does not roll and has a high degree of protection against chipping. I find that the M2 has a higher impact resistance (a measure of tougness) at 62RC than the ATS34 at 59 RC, and of course is much stronger.
While I really do like good ingot stainless steel like 154CM, they are not in the same league in regards to toughness (while retaining strength) as a high grade tool steel.
Chad
Chad
Cliff --
I've also used Opinels, and Schrade Old Timer knives. My unscientific feeling was that, straight from the shop, the Old Timers outcut the Opinels and pretty much anything else I know. Have you compared the Opinel with the Schrade or Camillus carbon steel series (some of which are lockbacks)?
I have an Opinel #8 and I must say that it's one of the best cutters I have.
Mine came shaving sharp NIB. To date, the only thing that cuts smoother is a japanese handmade knife from Moki.
My cutting tests are strictly non-empirical with a tolerance of whatever my mood is on any given day.
My standard is based on NIB Olfa blades and the cutting medium is 105gsm Springleaf paper
The Olfa sliced slightly poorer than the Olfa blade. The Moki on the other hand was way smoother than even he Olfa and offer less resistance.
This thread discusses altering of Opinel blades and handles. At least one participant mentions he removed the lock ring from his Opinel prior to working on its blade.
I own a Twistmaster clip point knife -- I believe it is 3.25 by .125 inches. I like its apparent sturdiness, simplicity, and grace, but I prefer a different blade shape and material. Questions pertaining to it for which I need answers:
1. How durable is its lock ring when compared with Spyderco lockbacks of the same size?
2. Is it possible at a reasonable price to replace its "Carbon V" blade? What I refer to is not the cost of a new blade, rather getting the lock ring off-and-on, and whatever else is required to restore the function of the knife.
3. Who can fabricate a blade?
First off, I have of late investigated the difference in applying the finish of the 100 grit AO belt by hand, and on the sander. There was no difference in edge retention. The belt sander gave slightly sharper edges to start, just an alignment issue as I had more control over the knife when using the belt sander. I intend to try the 40 grit belt finish again on the sander this time, I just need to pick up some belts. I will also be looking at the Opinel and Twistmaster with the 100 grit finish, they should be able to get 500, or maybe even 1000 cuts before losing paper slicing ability. The sharpness is also tested on thread and light poly for consistent comparisons.
In regards to the Twistmaster, the locking ring is very secure, but is much lower in terms of overall strength and durability as compared to a lock back from Spyderco. In regards to getting the blade replaced, you might want to ask on the Shop Talk forum, or the Custom forum to find a maker who is willing to have a look at the modifications.
-Cliff
Bonjour everybody,
Just a little note to share our thoughts about 1075 carbon steel.
Opinel number 8 is used to skin deers in the Highland. A lot of deers actually and by a professional...
Now I understand why...
1075 when well heat treated is really easy to resharp in the field.
"D2 is great but hard. 1075 is perfect in the field!" said a french commando teacher and knifemaker named Pépé.
cheers,
JM
