Waterjet or plasma will do the same accurate but way cheaper IMHO.
On the question of heat related problems from laser cutting, does anyone have direct experience with this that they can share?
I can comment on that. I program and run a laser for a living. The heat affected zone can vary quite a bit based on the cut. I can cut with very little haz, but it will take longer. I can cut fast, but the haz will be bigger. Thickness, material type, machine settings, assist gas type, and a number of other variables affect it's outcome.
What tolerances are you looking for? (Plus or minus how many thousands of an inch?)
What thickness and steel type?
Jamie
it has to be annealed after cutting since the laser machine blasts compressed air (or nitrogen for titanium)at the point of cutting which leaves the edge very hard. This is why I don't get stainless steel laser cut.
Well crap! I hadn't even considered the hardening of the edge where it is cut (and the holes as well). This is a potentially big problem with laser cutting. Annealing S30V will require a trip to the heat treater. Rats! Maybe it's possible to completely CNC mill the blades and lock bars, and water cut the rest. My current bandsaw method is just too time consuming.
You will probably find, as I did, that it's cheaper to waterjet your blades, etc. oversized (say .020) then CNC the blanks to size, since you're paying for time on either machine and waterjet should be cheaper (faster and no cutters to buy) than CNC for blanking operations. It also provides an opportunity to double-disc grind your parts to final dimension before going off to CNC. This way, you have an improved chance of getting your holes and edges square and perpendicular since the blanks will be precision-flattened before you hit the CNC.
Sometimes I wonder if the discussion about S30V sometimes chipping out, sometimes behaving well, sometimes chipping until resharpened, etc. has something to do with folks laser cutting that material, generating conditions along the edges that could explain some of the strange behavior.
The steel is S30V, 1/8" thick. The tolerance for the locking notch is very close, + - .002 is about it. Howerever, because the lock recess tapers, this isn't as hard as it might sound.
Again, you're not going to get a satisfactory cut for a lock face with just waterjet or laser. You will have to do some machining/grinding.
I'm not sure which tolerance would be +/- .002, but if it's the slop in the notch, I would think that would be excessive. For this procedure, I think I'd leave the lockface oversized and build a fixture to grind/lap it to final fit. If you have a CNC machinist that will work with you, you could get them to dial in the relevant tolerance until it's just what you want. I suspect you'll be talking about +/- .0005.
