laser engraving and stress risers
I am thinking about having a blade laser engraved (cross sabers for a cave guy I served with). My plan was to do it before heat treat but should I worry about the 90 degree angle as a stressor?
thank you for your time and advice
Dan
If you are making the blade from air hardening steel I don't see a problem. If not it would depend greatly on the depth of the engraving. If the engraving is rather shallow then not problem. If you are doing laser why not wait until after HT. The heat involved is very limited and should not cause a problem with the HT if that is what you were worried about.
My thinking was that it would be easer before I hardened the steel. I was going to use o-1 but I have plenty of steel options
It also depends on who's doing the engraving and what kind of laser they have. I haven't found anyone locally who will even touch hardened steel at a reasonable price for a small run... but I'm still looking. Trophy shops and those places in the mall just aren't set up for it, and industrial shops don't usually care to quote just a couple pieces.
How deep are we talking here? A few thousandths? Relax. I know of lots of makers who HT their blades with much deeper scratches than that all over the place. Every forger I know of stamps their blades before HT, and that makes a mark deeper than any laser-engraved logo I'm familiar with.
When we speak of stress risers, we're concerned mainly with sharp inside corners, like hidden tangs with square shoulders. Of course, you'll need to have your blades essentially finished and your HT better be clean, or you'll wind up sanding/polishing the mark right off.
I'd say they could happen with a deep engraving... very unlikely but still possible. Maybe a few passes on a scotchbrite belt or blasting would help eliminate the chance.
Good luck! I think this will go smoothly.
