This is the final version of the Laser Strike. As suggested by others on this forum we added a little cost and included a kydex loop for the striking rod, 3 feet of paracord wrapped around the sheath for bow drills or other uses, and the Ranger Band as extra security - so if the striking rod wears and becomes loose, the band around the top keeps it tight. The band makes decent rubber for a limited use sling shot when split length-wise and cut on the bonding point. The bow drill divot has been fully tested and works extremely well with no heat transfer to the users hand and actually gets slicker the more you use it. The divot also serves as a pivot point for thumb or finger when choking back to do light chopping - basically the same technique as pinch gripping a machete.
More info available here: http://www.jungletraining.com/laser.htm
Randall's Adventure & Training
jeff@jungletraining.com
[This message has been edited by JeffRandall (edited 11-03-2000).]
