- Jun 11, 2006
well i ordered the rest of the forge stuff i needed from darren ellis. it turned out a lot cheaper then buying one and plus i get to build something which is allways fun right. so my question is this. im going to be running a forced air burner in my forge that is made from a old air tank that is 9" wide by 16-17" long. it has slightly domed ends that make up about an inch on each side. what im wondering is this, should i put 2 layers of 1" Inswool HTZ 2700 or 1. if i do 2 that will make the chamber around 4" accross and if i do 1 it will be 6". but i will be adding
Ins-tuff Ceramic-Fiber Rigidizer
Satanite Refractory Mortar
Bubble Alumina
ITC-100
so i am guessing all that will what, maybe add 1/4" - 1/2" per side. so that makes my chamber eather 5" - 5.5" or 3" - 3.5". Is one layer fine or must i have 2. i would like the space of just 1 layer because i think 3.5" is kinda small for a chamber size, makes it kinda hard to keep the blade out of the direct blast of the burner. IF i do the one layer im going to make a 6" hole in the front and make a door out of 1" Insboard 23 HD with a hole in it. then make a 4" hole in the back and weld tracks onto the tank to hold another 1" thick insboard to seal it off but will alow to be removed. i would also think about using 1" Thick Hard Fire Brick for the floor to protect it from any flux. what do you think?
Bubble Alumina
ITC-100
