- Jul 3, 2014
I can see it in that picture. I have not had a problem with my LC at all, but mine is the non-racing, and I took it up to 25 DPS because I knew I was going to be using it VERY hard. Still, I can not believe that thin grind can handle the abuse I've put it through! I use it almost everyday on al types of pine, walnut trees, and even the core to really thick branches of Persian silk trees, which I was surprised how dense that stuff is.
sucks that happened. Might want to send it to Nathan to get it straightened, then take it to a thicker edge. Straight cutting/chopping is key too. Or maybe sell it after it is straightened and go for the medium chopper?
I am pretty sure this is a lean ground normal LC. that said I break shit without trying.
changing the DSP would not remedy anything as the bend is way above the secondary.
the edge itself still cuts paper after probably cutting 400trees.
