Prior to soldering, a line is scribed where you want your bolster to line up behind the pivot pin. Mine is about 3/4" from the end.
1. The parts were sanded flat by hand and cleaned with acetone.
2. Lightly put some oil on the places you don't want solder. The pin for the bolster will be used to help align it for soldering so make sure some oil is on the pin.
3. A small coil of Stay-Brite and Stay-Clean flux is placed on the piece and it is heated till the solder starts to melt. Dab the solder around on the piece with some scrap rod to ensure it covers the surface to be soldered. **This is pretty important - If you overheat it, it will turn a nasty brown and won't work. Heat slowly and back off on the heat once the solder starts to flow.**
4. Flip off the excess solder while it is still hot. The piece should be brite and shiney. Do all liner and bolster parts the same way.
5. Line up and clamp the tinned pieces on one set. Make sure you use the pivot pin to help align the parts. Heat up the bolster side till the solder begins to flow. Thereafter you will notice the liner side solder will begin to flow...stop with the heat and let it cool.
I used this method on mine and overheated my first set. While it was cooling I "got back on the horse" and soldered the second set. It worked great! I cleaned up the first set and did a re-run....no problems. The important things are to clean well and not overheat. Tony says he has soldered all his liners this way and has never had one come apart.
That's basically it and thanks for the question. Take a look at
http://boseknives.com/backpocket-construction/ and peruse pics 3 thru 14 for the soldering sequence.
By the way I registered
http://boseknives.com for Tony back in November and plan on building this site from the ground up. I know a lot of you professional knifemakers have web sites with some great content. If you're open to sharing them, I'd like to here your ideas about things you would like to see on BoseKnives.com. You can send me messages off forum if you like.
