Keep in mind that here stainless steel, most likely cookware steel not 60HRC blade steel.
I did not warm intentional, just keep lamp close to sharpening surface and it is good to see precisely what I you doing if you want precise edge and as I side effect it melts slightly - actually just soften compound.
So, I finally found catalog of WoodCraft (not WoodWork sorry):
Green rouge in WoodCraft Catalog - 06L01 "Micro fine honing compound" 20 oz Bar, $20.99 it is actually 0.5 microns!!! And I thought why it is sometimes better then 1 micron diamonds and I was able to split/shave hair right after it? Ha!
http://www.woodcraft.com/family.aspx?familyid=3112
Tip - Best way to wash this thing off the blade coating (I had problem with Busse) is soap.
BTW: I also found there
124629 - sharpening paper wheel for grinder
15T31 - Leather powerstrops
Thanks, Vassili.
P.S. Oh Sorry, here it is actuall Green Rouge (#85H28) from Same WoodCraft:
http://www.woodcraft.com/family.aspx?FamilyID=4240&cs=4242
For $7.50! I remember that it was less then $10, not $20...This is what I have - other one, may be different.
Leather they have for honing is too thick to my taste. It is hard but not good enough to split hair.
