Got a few drawer jockeys here to swap. I'll describe them best I can and represent condition in photos the best I can as well. Trades are limited to the US 50 and both parties must agree to USPS Priority shipping. Not too keen on trading unless you have some verifiable feedback or solid deals.
1)Leatherman Charge ALX, carried more than used and only on the pocket clip, never in the sheath. Light marks on the hard anodized aluminum scales. All of the tools lock tight. Comes with QD pocket clip, lanyard ring, deluxe sheath and complete bit set. Has been Frog lubed.
2) original USA made Gerber Multi-Plier. Has Simonds metal file. Has been used a bit, file has some discoloration as well as the pliers, main blade could use a sharpening. Still very serviceable, comes with original Cordura sheath that is a bit dingy.
3)Victorinox OH Master RT edition. LNIB limited production. Like a Forester dual grip but replaces the saw with a metal file, and the cork screw with a Philips driver. Grey dual grip scales.
*I will throw in a SwissBianco 111mm SAK pocket clip kit with the OH Master, I will caution to install at your own risk. I purchased the clip preinstalled on new scales and the fit was horrible; the backing plate sat proud of the scale not allowing the scale to fit flush. I had to grind the backing plate a bit and a bunch of plastic from the back side of the scale and still could not get a decent fit. I don't want to fiddle with it anymore. Good concept though for adding a clip to the 111mm SAKs. ***THIS WAS NOT INSTALLED ON THE KNIFE ABOVE***
4) Not pictured, Spyderco Dfly Salt SE, carried used exc. cond. w/box
Pics up in a bit...
I'm after-
Emerson Prestige Traveler
Emerson Micro Comm
Benchmade 915 Triage Orange in the non blunt tip, prefer satin finish.
BM 530 PE or SE satin finish
BM 300 PE or SE
BM 707
BM 556 M4
ZT 0550 either gen. Blems are no problem..
Boker Burnley Orange if lock up is solid
Spyderco Goddard Lightweight OD Sprint
Pics up in a bit...
I'm after-
Emerson Micro Comm
BM 300 PE or SE
BM 707
BM 556 M4
