- Jan 11, 2019
I end up hand sanding all of my kitchen blades but I set up hand sanding with length wise grinding on my 14" contact wheel.
I grind the bevels on both hard and felt platens to create a hybrid full flat/convex profile.
My grit progression is ceramic 50 then 80 on the flat platen down to around 0.03" followed by felt platen grinding. I use ceramic 80 and 120, then 3M gator belts A300, A160, A100, A65. All of this is perpendicular grinding.
Then I switch to length wise grinding on the 14" contact wheel. For AEB-L I can usually go to gator belts starting at A300 and on down to A65 or A45 then on to hand sanding which is really just refining things and doesn't take very long. If I'm using a higher alloy steel I usually start length wise grinding with ceramic 120 then to A300 gators and on down.
I guess when you change to vertical its only finishing work? I ground out my convex edge when I switched to the wheel last time.
