- Apr 15, 2014
Asking prices are PP Goods and cover fees and shipping. First "I'll take it" by post, PM, or email takes an item.
THE FLASHLIGHT
I am second owner of this flashlight, for which I recently traded. It is a Lenslight Mini Titanium Digicam flashlight, which I do not believe are currently available. It was lightly carried a few times by the original owner, and I had to look very closely and multiple times to find a few very faint lines in the midst of the digicam. Very faint, very thin, very few, nearly undetectable. I have excellent eyesight, and I had to twist and turn the flashlight over and over under bright light to find them. With the flashlight at arm's length, you couldn't see them...maybe even at a shorter distance. I should probably offer a prize if you can actually find them!
In any case, it is a dual output (low/high) model with memory. The output setting toggles if you turn the light off and then back on within 2 seconds. You can select brightness level by partially depressing the button (short of a full click) to toggle between the settings. Full click to turn the light on at the desired setting. It comes with a pocket clip and a lanyard ring, in the original bag with manual. The screw for the pocket clip is slightly marred but appears to still have the torx slots intact. (I haven't tried to install the pocket clip. I've done nothing with it since receiving it, other than testing it.) This is quite an attractive creation by Lenslight, and I am hesitant to sell it, but I have an HDS Tactical with which I am very happy/attached. I won't be heartbroken if this doesn't sell, but it feels a bit like having Tom Brady as backup QB to Aaron Rodgers. A bit overkill, don't you think? Last time these were available, they sold for $450 (according to Lenslight). $375 OBO
Click HERE for more pics.
THE SCALES
I have three scales for sale today.
First (top scale in pic below), a custom "maroon micarta linen" ZT 0562 scale made by Six Three Blade Worx. I think I mounted it once for a few minutes, and then decided to go with a different custom scale (Patriot Kirinite, from the same maker). Purchased directly from the maker. Fantastic scale, but I sold the other 0562 on which this would have been mounted. $45 OBO
Second (middle scale in pic), a Hinderer XM-18 3.5" translucent green frag scale from Monkey Edge. It was mounted, but I don't believe it was ever carried. Not certain. However, other than the dark marks down in the screw holes (which will not be visible when mounted), it looks pristine to me. SOLD
Finally (bottom scale in pic), a custom purple G-10 ZT 0550 scale made by Suingab, who, I believe, is a BF member. I mounted it and carried it 1-2 times. No signs of wear. I simply ended up removing it and selling the ZT 0550. Comes with an orange G-10 LBS (also made by Suingab). $30 OBO
Make an offer on any of the scales. I'm motivated to move the ZT scales, in particular.
THE FLASHLIGHT
THE SCALES
