Lenslight Mini Titanium Digicam Flashlight
Feedback: +164 / =0 / -0
I am second owner of this flashlight, for which I recently traded. It is a Lenslight Mini Titanium Digicam flashlight, which I do not believe are currently available. It was lightly carried a few times by the original owner, and I had to look very closely and multiple times to find a few very small and faint lines in the midst of the digicam. Very faint, very thin, very few, nearly undetectable. I have excellent eyesight, and I had to twist and turn the flashlight over and over under bright light to find them. With the flashlight at arm's length, you couldn't see them...maybe not even at a shorter distance. I should probably offer a prize if you can actually find them!
In any case, it is a dual output (low/high) model with memory. The output setting toggles if you turn the light off and then back on within 2 seconds. You can select brightness level by partially depressing the button (short of a full click) to toggle between the settings. Full click to turn the light on at the desired setting. It comes with a pocket clip and a lanyard ring, in the original bag with manual. The screw for the pocket clip is slightly marred but appears to still have the torx slots intact. (I haven't tried to install the pocket clip. I've done nothing with it since receiving it, other than testing it.) This is quite an attractive creation by Lenslight, and I am hesitant to sell it, but I have an HDS Tactical with which I am very happy/attached. I won't be heartbroken if this doesn't sell, but it feels a bit like having Tom Brady as backup QB to Aaron Rodgers. A bit overkill, don't you think? Last time these were available, they sold for $450 (according to Lenslight). SOLD
Click HERE for more pics.
SOLD LNIB Maratac Extreme AAA Polished Stainless Steel Flashlight. Rev 3 (latest) with the glow-in-the-dark o-ring just inside the lens. Purchased from another BF member as "brand new," and it appears so. I've not carried or used it either. Comes in original box with two extra o-rings and a glow-in-the-dark diffuser. SOLD
