Certainly not arguing with you,as said, I'm an oil-using proponent, but I am curious about the effects of viscosity. For example, if I use the heavier digestive-type mineral oil, I find it too thick. Maybe it is just deadening the feedback so I feel like it's not working as well?
Just curious about your thoughts there.
To clarify, I was only taking issue with the statement in the quote, not any statement by you. A lighter oil is usually better, certainly, but thicker oils still provide benefit over dry use.![]()
This is what I've noticed. Plus, when using a finer stone it doesn't take much swarf to load it up. Then your efforts are diminished until you clean it. DMAlso agree that most any oil will actually speed cutting, instead of the reverse. Multiple things playing into it, such as keeping swarf out of the way & preventing clogging and sticking of the swarf to the grit itself, etc. Whatever mechanism is actually working to that end, I've noticed it definitely makes the process easier and faster, rather than not. I've also noticed that on my diamond hones, used with oil. Makes a big difference on ceramic hones especially, which load very, very quickly otherwise.
I used to notice, in the first very few passes on a completely DRY, CLEAN stone, the cutting action feels VERY aggressive initially. That would sort of imply the stone is working better, used that way; but the problem is, the stone will begin to clog immediately as well. So that very aggressive-feeling cutting action goes away very fast, until the stone is cleaned up again.
There is some minor dulling of the feedback felt, using some of the thicker oils. But it's very minor at that, and essentially insignificant in my uses, especially when used on coarser stones (no shortage of feedback with those).
Yes, this is above Sharpening 101. DMThis is one slick thread for those neophytes that have the grit to get through it since some of the lessons are somewhat counterintuitive. .
I don't typically use oil, but for light mineral oil, your local agricultural store probably carries gallon jugs of it for livestock. It's thinner than the pharmacy stuff, and while I don't believe it's rated as "food grade" for humans, it's good enough to still be given to critters, so a tiny amount that gets on food is probably of little concern.
OH GEE !While we're beating dead horses, I've mentioned a few times that I like to use glycerin, especially for ceramic stones. I just hate having to scrub with Barkeeper's Friend so often to keep the stone from loading up. The glycerin floats the swarf while sharpening, and cleans with a wipe.
It works with diamond and India stones too, but it really makes a difference on the fine ceramic.
Hahahaeyeballed a gallon jug of that stuff at our local Tractor Supply store, a while back . . . . I'd already bought some of the pharmacy stuff, and had a couple small cans of Norton's oil, . . . acquired two bottles of the food-service lube oil at the restaurant supply store. I think I'm set for a while...![]()
