Let's see your impractical knives
While at first this knife may seem useless, I finally found a reason to own one.
(Review)
http://www.bladeforums.com/forums/showthread.php?t=811920
Spikes, bro.
What are those knives called? I'd like to check them out, just for fun ;)
And if my Cold Steel Grosse Messer counts (German for big knife) it is my most impractical knife.
I was going to say my Cold Steel Rajah I was impractical, but since I carry it regularly and since it would do just about anything I asked of it, I guess it isn't impractical...
not quite as impractical as some but here they are, add in a MICROTECH SCARAB too, just got it post picture....
I drive a practical car but when it comes to 'practical' knives I wouldn't be caught dead with one. I'm sure you sad sacks would not find many of my dozens of knives to be 'practical' , and that's exactly why I find them to be very cool.
Of course if 'cool' means nothing to you, I would be happy to give your impractical knives a home where they'll always be much appreciated.
hahaha
as far as I can tell, mine are all rather practical. The only thing bigger than about 4.5 inches is an axe, and that gets a ton of use :D
maybe my ESEE 3 was, because it was my first "expensive" knife at almost $100, and then I rarely used fixed blades any ways. Now it sees more use, but I admittedly like my Moras much more.
I guess if I was a professional knife fighter this would be great, but......I'm not...a professional. I like it though. CarbonV; IMO you can't go wrong :)
I would actually like it if it had sane ergonomics and more than a millimeter of zytel-like material holding the whole thing together.
And a v grind.
And scales that fit.
1. 2.5” 60% Serrated locking blade
2. Nail file, nail cleaner
3. Corkscrew
4. Adjustable pliers with wire crimper and cutter
5. Removable screwdriver bit adapter
6. 2.5” Blade for Official World Scout Knife
7. Spring-loaded, locking needle-nose pliers with wire cutter
8. Removable screwdriver bit holder
9. Phillips head screwdriver bit 0
10. Phillips head screwdriver bit 1
11. Phillips head screwdriver bit 2
12. Flat head screwdriver bit 0.5 mm x 3.5 mm
13. Flat head screwdriver bit 0.6 mm x 4.0 mm
14. Flat head screwdriver bit 1.0 mm x 6.5 mm
15. Magnetized recessed bit holder
16. Double-cut wood saw with ruler (inch & cm)
17. Bike chain rivet setter, removable 5m allen wrench, screwdriver for slotted and Phillips head screws
18. Removable tool for adjusting bike spokes, 10m hexagonal key for nuts
19. Removable 4mm curved allen wrench with Phillips head screwdriver
20. Removable 10mm hexagonal key
21. Patented locking Phillips head screwdriver
22. Universal wrench
23. Laser pointer with 300 ft. range
24. 1.65” Clip point utility blade
25. Metal saw, metal file
26. 4 mm allen wrench
27. 2.5” blade
28. Fine metal file with precision screwdriver
29. Double-cut wood saw
30. Cupped cigar cutter with double-honed edges
31. 12/20-Gauge choke tube tool
32. Watch caseback opening tool
33. Snap shackle
34. Telescopic pointer
35. Compass, straight edge, ruler (in./cm)
36. Mineral crystal magnifier with precision screwdriver
37. 2.4” Springless scissors with serrated, self-sharpening design
38. Shortix key
39. Flashlight
40. Fish scaler, hook disgorger, line guide
41. Micro tool holder
42. Micro tool adapter
43. Micro scraper-straight
44. Reamer
45. Fine fork for watch spring bars
46. Pin punch 1.2 mm
47. Pin punch .8 mm
48. Round needle file
49. Removable tool holder with expandable receptacle
50. Removable tool holder
51. Multi-purpose screwdriver
52. Flat Phillips head screwdriver
53. Flat head screwdriver bit 0.5 mm x 3.5 mm
54. Spring loaded, locking flat nose nose-pliers with wire cutter
55. Phillips head screwdriver bit 0
56. Phillips head screwdriver bit 1
57. Phillips head screwdriver bit 2
58. Flat head screwdriver bit 0.5 mm x 3.5 mm
59. Flat head screwdriver bit 0.6 mm x 4.0 mm
60. Flat head screwdriver bit 1.0 mm x 6.5 mm
61. Can opener
62. Phillips head screwdriver
63. 2.5” Clip point blade
64. Golf club face cleaner
65. 2.4” Round tip blade
66. Patented locking screwdriver, cap lifter, can opener
67. Golf shoe spike wrench
68. Golf divot repair tool
69. Micro straight-curved
70. Special tool holder
71. Phillips head screwdriver 1.5mm
72. Screwdriver 1.2 mm
73. Screwdriver .8 mm
74. Mineral crystal magnifier, fork for watch spring bars, small ruler
75. Removable screwdriver bit holder
76. Magnetized recessed bit holder
77. Tire tread gauge
78. Reamer/awl
79. Patented locking screwdriver, cap lifter, wire stripper
80. Special Key
81. Toothpick
82. Tweezers
83. Adapter
84. Key ring
85. Second key ring
....still looking for a belt sheath for it :eek:
[youtube]rn7aLRifOZ0[/youtube]
