Couldn't agree more with you Adam. But unfortunately, what I keep seeing is stuff like this on the internet. You try telling them that's dangerous, and they come right back around and tell you, "No it's not, it's not dangerous". It's no wonder guys are getting hurt.Knowledge is power. Here is a video covering the basics
Burr King makes a tapered spindle end like the Baldor ones. It screws on in place of the wheel nut and has a set screw to hold it on. I can simply take the wheel off and put the spindle on. Then I can change buffs quickly. I have 10" buffs because I usually have the 10" wheel on my grinder. I can keep the platen, and work rest in place. I hope that makes sense. Any other questions, please let me know.
Yesterday got a delivery with various wheels and compounds. I was eager to try things out as I have not buffed anything but edges on hard felt before, so I went at a Redwood burl handle this morning. Here are the before and after pics. Before is hand sanded to appr 1200-1400 and treated with linseed oil + terpuntine, dried/cured.
After is from three buffing steps. I used 1"x10" mops at appr 1500 rpm. Steps:
1: Menzerna G113GZ (like Tripoli) on loosefold B mop. (Maybe could have skipped this step due to fine hand sanding?).
2: Menzerna GW16 (a rather greasy finishing compound for composite, plastic etc) on loosefold G mop.
3: Carnauba wax on WDR loosefold mop.
I'm very pleased with the results.
I'm pretty sure that flexible shaft would increase its ability to grab a knife blade and throw back at you, especially it the shaft got even slightly bent or a bit out of alignment and started vibrating or wobbling on you during use. All I do know for certain is, I would never use a machine like that to buff a knife blade or anything. That all thread rod is so flimsy even bumping into it when it's not running could bend it or throe it out of alignment.Hah, well that is interesting.
It's definitely not something I would have thought up, but for full disclosure, what potentially dangerous scenario are you thinking could happen with that setup? I'm guessing the obvious is the fact that the shaft material is too weak as well as too small in diameter for it's length & its application (making it even weaker), which requires being able to withstand decent amounts of sideways pressure. But would the danger involve the shaft potentially warping or even breaking while the motor is running causing things to flay apart? It's always a plus when I can personally learn things from others' mistakes rather than only from my own lol.
"A smart person learns from his mistakes, but a wise person learns from the mistakes of others.”![]()
~Paul
My Youtube Channel
... (Just some older videos of some knives I've made in the past)
The little Foredom machine is good for polishing smaller items. It is no more/less dangerous than other buffers.
While it is an excellent machine, I would prefer a larger unit for knife work.
