Let's talk about hammers now
I post on here alot I know. I should probably see someone about that. Some sort of addiction maybe. But until then I wanna see your hammer :p
Forged once, now I'm hooked. All I have is a 3lb crosspein from tractor supply. It's very nice and I enjoy it so far nut it's on the hefty side. And the face is pretty big. I was thinking about a 1.5lb dog head hammer or rounding hammer of the same weight. What say you? And where do you buy your hammers? Should I just get a 4lb sledge head and shop the back end off?
Finished these last semester. 5, 3 and 2 pound.
I have one hammer from Jackpine Forge, two I more made in Nathan's classes. The first hammer has held up to countless student lending - highly recommend.
This is the one, and first and only, that I got my son for christmas. We will both be using it to begin our pounding metal adventures just as soon as this darn anvil gets here in the mail. We have both swung it a bit to test it out and feels just right for both of us. It is 1000gr or 2.2lbs.
It is the dressed version since neither of us knows how to dress a hammer. Figured it would be good to have something properly dressed so that we have a reference for future hammer dressings.
^^^ That little one is a tack hammer. It is probably magnetic on one end to hold the tack while you set it on the first blow then switch to the opposite head to finish driving it in.
I suppose I have an epiphany waiting for me someday when I try expensive custom hammers.
I have a lot of hammers and purchased most of them at local stores. The exception is a railroad engineer's hammer I bought off Ebay because it had a straight pein. I have an 8 lb sledge that I cut the handle down for big jobs and for striking my maker's mark, a 4 lb sledge, a 2.5 lb cross pein, (5)3 lb cross peins with slightly different flat faces and a variety of pein profiles, (5) 2 lb engineer's hammers with flat faces on one side and a variety of rounding profiles on the other faces, a variety of ball pein hammers from 4oz to 32oz ( a 24oz Vaughn being my favorite), A masonry hammer with the pick part cut off of the back end making it more of a dog's head type and a tack hammer like the one above. They all get used.
Maybe I'm missing something. You guys that are more knowledgeable about hammers can explain. As far as I can tell, there are three things that are important with hammers- weight, profile and technique. I buy hammers in the weights I want, I dress or profile the faces for the tasks required and then I use the hammers in a way that makes the best use of those modifications. That can be done with hammers found online, at local stores, swap meets and garage sales or those found at the junk yard. A lot of my hammers came from Harbor Freight. They are cheap, come in a variety of weights and shapes and I can easily shape them any way I want.
The important thing is that your main hammer be comfortable to swing for long periods of time. It should have enough weight to move metal but light enough so that you can place your hammer blows exactly where you want them.
The only thing I would add to your criteria Marc is balance. I'm like you, all of my hammers are various cross peen, engineer or ball peens that I bought local and modified save one dogshead I got as a gift and a french peen that was pretty inexpensive.
Haha, I knew someone was going to mention balance. I kinda group that with weight. The thing is, most standard pattern hammers like the engineer's, cross pein and ball pein are pretty well balanced.
^^^Yes they are $$$
That's why I have what I have.
Although I do think about making one, one day, out of a piece or railroad track when I get a press up and running.
If an engineer's hammer is neutral balance, every hammer I use for general forging is modified to be front heavy. I don't care for neutrally balanced hammers.
I've been thru many hammers including custom made for me etc.
best hammer I have for me is a Vaughn ball peen 40 0z.
recently I took a large Vaughn 40 oz ball peen and ground the head into a straight pein.
most important was to cut the handles down to a much smaller length, then shape the handles with flat sides to my liking
These hammers are considerably weighted front forward similar to a Japanese dog head hammer
https://www.bladeforums.com/threads/sharing-some-forging-hammer-info.1538856/#post-17673355
