Let's talk dust collecting systems for a bit...
Phillip when you were at my shop you probably saw that I just pull it all outside and deposit it there, however I have the exhaust fan from hell and in the winter it will drop the temperature of my shop 10 Degrees within 5 minutes. I simply cannot afford to heat my shop like this anymore so this summer I will be insulating the walls better and rerouting that blower exhaust into a cyclone separator and then back into the shop.
Cyclone separators are less of a hassle than filters and don't impede the airflow in any way, I will probably put a light filtration unit on the incoming line just to catch really fine particles. But if you have your shop sealed up and insulated quite well you need to consider one factor often overlooked with just blowing things outside- equalizing the pressures and the creation of vacuum. In order for your furnace to work properly it needs cold air returns to pull the heat through the room, otherwise you are moving less air as it pushes against a pressurized room, the same is the case with suction. Your filtration system will work much better if you can put the air back into the same room and equalize the pressures instead of creating a vacuum that you must fight.
Also be careful to balance out your pipes properly so that the length and diameter is appropriate for the desired airflow, many people make the mistake of using smaller inlets for initial airspeed and then going with too large a diameter main line. The main line has to be larger than your intakes in order to provide adequate and equal suction on them but if it is too large there will be a drastic drop in airflow speed and you will get settling and build up in the main line which will require frequent cleanings to unplug things. Also the smoother the inside of the lines the better, sharp corners and rough surface or ridges will create turbulence and pockets of low pressure where particles will settle out.
"Gosh Kevin, why do you have all this anal information about air systems?" Because the room next to my grinders is a lab with several expensive microscopes, ultra-sensitive polishing equipment and many other gadgets that cannot tolerate dust or grit, not to mention my stereo system. I have been playing this dust elimination game for a few years now on a level most don't have to worry about. Stacy's idea about blowing the dust out is a good one, but I do it weekly with a high pressure air hose. And after all this, I still get dust in the lab.
A very good and inexpensive book on this topic is "How to design & build Centrifugal Fans for the home shop" by David Gingery ISBN: 0-917914-60-0
Along with the fan information it discusses proper ducting and separation.
2HP will work great. I'm using 4" pipe, with a 5" exhaust out the wall. My longest run is about 10' and I would call 24' a long run for a vac system.
I guess I could shorten it to 16', maybe less.
Thanks for the additional info, Kevin. I was very impressed with the suction of your system. Did you build your own blower?
I had remembered that Lindsays Techical Books sold a book about making fans, and was tempted to get it, but I decided I'd rather save time and buy a system. Sounds like it may be the same book as you're recommending. I'll probably go ahead and get, anyway, for the ducting and seperation info.
My shop is not sealed at all, so pressure equilibrium should not be an issue.
The collector I bought comes with a cyclone separator, so that's good.
Well for me I let God do it for me :) Im lucky enough to have such a small "shop" that it is under a car port and on a good windy day everything works itself out. :D
I do however use a resperator when working with Micarta.... stuffs harsh...
Oh I use a big ol Shop Vac of course but I dont seem to have the issues you real makers have.
Now at work... thats a different animal all together. I dontt think there is anyone on this board who wouldnt be impressed with my nuisance collection system. I work in a Kraft Foods powder packaging room and well the fans are as tall as me and Im 6'5" :) Anyway Im enjoying this thread and Im thinking about buying the Harbor Freight collector for when I get my shop.
Thanks for the interesting thread!
