I replaced the washer's on my Fallkniven PXL from teflon to p/b. Did so because I usually tighten my pivot a little more than most and was afraid it would tear the teflon as I have read some posts about this very thing happening. Before hand my PXL's blade was perfectly centered when closed, with the p/b washers it was off center just a smidgen, but enough to make an OCD knifeknut cringe! Another problem I ran into was with the opening. With the teflon it opened very smooth, even when I had it tight to my desired spot. With the p/b washers, I ended up with a seriously sore thumb!! I had miked the teflon washers, and got the p/b washers to the same dimension by sanding them on some 2000 grit wet/dry paper. I used a drop of miltec1 on it, then went back and took it off trying it without any, but it didn't seem to make much difference, still a sore thumb. In the end I went back to the teflon and it made my thumb feel a whole lot better!
A lot of the knives I buy now have p/b washers, and for the few that don't, I replace with p/b washers. But I've never had the trouble that I did with the PXL.
