- Oct 4, 2017
Morning all again,
Looking for another chart
. I can't find it anywhere. What letter sizes should be used with which fractional size?
Thank you.
Thank you.
A standard twistdrill will always bore slightly larger than its diameter. Its just the nature of two cutting edges & flutes weeblewobbling their way thru.Yes, I am talking for pin holes.
Interesting, The holes I have drilled with 1/4 bit are too large for my 1/4 pins. The pin slides easily through them. So I assumed letter bits were used to fix this by being a little smaller.
I am drilling with my old delta 12" drill press. It seems very steady and I just got a new chuck on it.I have found little pin variation over the years but it has occurred. How are you drilling your holes would be a bigger question to me and does the press have any runout (wobble) to it. A more likely reason for your 1/4" holes to be oversized. Years ago I use to use all kinds of different sizes and have now (probably 10 years ago) standardized on two sizes 1/8" pins and 1/4" pins and thong tubes. I use a #30 for the 1/8th" hole and a F for the 1/4".
