Thinking about picking up another CR folder after being without one for about 5 years. I used to have a Large Sebbie which I was very happy with so that was what I was going to get again, but now I see there is a new model "Umnumzaan".
In comparing the 2 I see that the Zaan uses a larger pivot but no bushing system. The Bushing pivot was IMO a great feature of the Sebbie, so I am a little disappointed that the Zaan lacks it since it was a great feature that set Reeve folders apart from the rest. (I almost wonder if the change is more of an improvement or a cost cutting measure? I have assembled many folders that use bushing pivots when I worked at Microtech and it's a real PITA in manufacturing to make bushings for each blade and keep them all in tolerance.)
As I see it the pros for the Large Sebbie are:
Bushing Pivot System
Proven Design
Lighter Weight
Traditional Blade Profile
Pros for the Umnumzaan are:
Larger Pivot Assembly
Thicker Blade
Texturing on the Handle
Rubber Rings on Studs (Although this could be a wear item?)
Which one do you guys prefer, or does anyone have some thoughts here?
Best Regards,
Alphonse
Proven Design
Lighter Weight
Thicker Blade
Best Regards,
Alphonse
