Very cool thread idea, Rick. Thanks for sharing your experiences!
I started making knives because factory knives sucked in the 80's. They haven't gotten a whole lot better since, although some have gotten a whole lot more pricy. Like Justin, I just plain enjoy making things, so that helps... although also like Justin, my persnickety side can make me over-think things and that's usually not conducive to high productivity.
Does anyone have tales of why they choose a particular process? That kind of thing?
Hidden tangs - I generally prefer full tangs because it's simpler to keep them strong, but I'm also certain that hidden tangs can also be plenty strong.
Satin finish - I like a hand-rubbed satin finish because it looks sweet. It's also pretty easy to take care of and if taken to a fairly high level, helps prevent corrosion just by not having deep scratches for gunk and moisture to "grab" onto. I like to go to 1000 grit and step back to 800 for a basic satin, but I've sold knives with 400-grit finishes and ones with 2000 grit; it just depends on the client's preference. I'm not crazy about buffed mirror finishes, but that is purely an aesthetic choice. I'm also not crazy about machine-satin or bead-blasted finishes, but if that's what the client wants, who am I to judge? That's usually more of a budget thing. Let's face it, hand-sanding is a freakin' chore and if someone doesn't want to pay me to do it... I'm OK with that.
Geometry - Geometry is KING. A blade with properly tuned bevels and balance for its intended use, made of scrap iron, will out-cut a clunker made of the very finest super-steel. Not for very long... but it will. My aim is to design a knife that will cut, chop and/or pry extremely well, then select steel and HT that will allow it to perform as long as possible without failure. Generally speaking, I believe thin is in and light is right.
Grind Style - I am no fan of hollow grinds. I have no desire to make a blade weaker all along it's length in order to get the same thin edge, and I do NOT buy the Loveless argument that a hollow knife will be usable longer, to any noticeable degree. If you have to sharpen the thing so much that you're wearing off a significant amount of blade and getting into the thicker material, you chose the wrong steel/HT and/or the thing was ground like an axe to begin with. I like full-flats and full-convexes. My convexes are pretty close to flat. I will (grudgingly) do sabre or sabre-vex grinds.
Pins or Bolts - I like bolts.
Nicely peened pins are a very close second. Un-peened pins tubes and mosaics add lateral strength but don't do much to keep scales tight to the tang. I use epoxy strictly to seal things up and prefer to rely on mechanical means to hold my knives together. Having said that, one of my earliest projects is a hidden-tang K-bar blade with "mortised" pakkawood scales held on only by dimestore super-glue, and it's chopped many a sapling and pounded many a tent peg with no qualms. But I prefer a belt
and suspenders, so to speak.
Forging vs. stock-removal - I'm a sparkmaker. I take perfectly good steel and make it smaller. I don't make a whole lot of big honkin' choppers or bowies, so there's simply not much to be gained by me investing another bucketful of cash/time in the tools/techniques required to forge properly. The only thing I have "against" forging is that in less-than-expert hands, there's a lot more that can go wrong and make a good piece of steel, worse.
Steel - I was once an unapologetic carbon steel snob. But the older I get, the less I enjoy sharpening and other maintenance. Happily, there are lots of great stain-resistant alloys available today that perform at or above the levels of the best-treated "plain" carbon steels, with a heckuva lot less maintenance. I don't feel any need to restrict myself to one type of steel, I'm just grateful there are so many really awesome alloys around these days. I feel it's silly to bother with old saw blades, leaf springs and so forth when truly wonderful fresh, virgin steel is a click or phone-call away*. Choosing one depends mainly on the clients' requirements. Which brings me to...
Clients - I have an irrational dislike for the term "customers". No hard reason for that, it just reminds me of slinging a nasty burger through a drive-up window at someone. "Take what you get and like it, slob! NEXT!"
My job is to help folks get the knife of their dreams in their hands. I do my best to build knives that will outlast me and the client, and be passed on to their progeny, and I charge accordingly. I think that deserves a bit of class and respect on my part.
* I do still make knives from worn-out files occasionally. I make no bones about it, and I ask much less for such knives than ones I make from the finest alloys. I just can't bring myself to throw away a decent piece of carbon steel
Whew, another marathon post from ol' James... hey, you asked!
