- Feb 28, 2011
You could always fill your containers and then use the lifestraw to drink out of them. Not an ideal solution for backpacking, but certainly viable for emergency situations.
@gadgetgeek. Most of the survival stuff online is highly paranoid. That article seemed good as it relates to a wide range of water filters. I did not read the rest of the blog.
@druid189. I'm not sure exactly what you are referencing... Was there something about fluoride in the articles I linked? Where did that come from?
. . . No mechanical flter can take out dissolved chemicals or viruses.
To the people using UV wands... how do you get the particulates out of the water so no viruses or bacteria that are encapsulated in them end up in your gut since the UV wands cant kill them?
For UV all you need is to get the particles out, and those are pretty big. a simple few layers of cloth will get most of them, and settling/decanting will get the rest. Anything smaller than that shouldn't be a problem.
A quick read of the survivalist blog just reads like the guy is super paranoid. But here is the thing. He is so concerned about dissolved chemicals, but the reality is, if you have a chem spill, nothing is going to be purifying that water. Any petroleum contamination will melt the inside of the sawyer. double filtering just seems like a waste of time to me. espessially using a couple hundred dollar filter as a pump for a cheap one. If you want to pump from the sawyer, just go build a pump, it'd be cheaper.
most of the stuff that is going to get you is parasites, and amoebas. Algae is fine, (unless its blue-green or red) in which case no filter will be enough. Parasites are huge, as are amoebas. Bacteria might be little, but they don't live long, and there are few that are really bad for you. (you are not likely to find e.coli in your back country water, unless you are downstream of the septic tanks)
yes, there are some bad water things you can get. Most people get sick from fecal contamination of food, not their water. But everyone blames the water.
Alternatively, I've used this without any ill affects:
[video=youtube;eTnAp0BX3SU]https://www.youtube.com/watch?v=eTnAp0BX3SU&index=1&list=PLDQGTzpfNRCtD24rQg1CTNuRO-iu6AOei[/video]
Good "catch" on SODIS, especially considering all the containers scattered about the backcountry by two-legged pigs (with apologies to four-legs). Survivorman had an episode in the desert with several old wiskey bottles present but Les Stroud ended up consuming questionable water (rodent droppings) without any treatment because, apparently, he didn't speak SODIS.
As for the second AV, as you doubtless know, regular chlorine pills and iodine are both doubtful for treatment to eliminate parasites. The idea for an expedient pre-treatment filter is great, and the cotton balls - and even the plastic parts - have alternate utility for fire-starting. Another example of why this forum is a great resource. Thank you.
Pre-filtering will only ever remove large particulates and not the 'nastys' that make us sick.
I've prefiltered with socks, shirts, canvas, etc., and have never gotten sick yet, and I have a sensitive GI tract. Going on over 10 years, and it works well. I also use it when filling my bottle from a drinking fountain in an airport - can't be too careful. I get strange looks, but don't care...To the people using UV wands... how do you get the particulates out of the water so no viruses or bacteria that are encapsulated in them end up in your gut since the UV wands cant kill them?
I've used a lifestraw a couple of times but never owned one. I use a Sawyer filter on all of my camping trips.
I don't really see any reason to get a lifestraw instead of a Sawyer filter.
Sawyer Mini vs. Lifestraw:
Weight- Sawyer weighs less by 57 grams (assume tie after adding bottle and accessories to Sawyer)
Size- Sawyer is slightly shorter (again, about a tie after adding accessories)
Effectiveness- Sawyer lists more significant digits in their effectiveness ratings but we'll assume they're practically the same
Life- Sawyer by a long shot at 100,000 gallons vs only 264 on the Lifestraw
Usability- Sawyer has a straw attachment so can do the same things as the Lifestraw, but also easily screws onto standard bottles making storage/transport easier.
Cost- Sawyer is $1 less on the largest online retailer
Basically I just can't think of any reason to get a Lifestraw instead of a Sawyer. Perhaps if you will only ever use it as a straw and want the convenience of wearing it around your neck; I'd be worried about losing the straw attachment on the Sawyer wearing it around all day.
