Originally posted by hollowdweller
another way to carry it rather than the kind of heavy sheath with the extra knives.
You can significantly slim down scabbard as provided, it's fairly simple.
Note that I have not actually done this,
but I've examined the construction
& plan to do it one one or two scabbards.
Remove the blades
Slide frog (belt hanger) down and off.
You now have 3 pieces of wood covered in leather.
The leather is held together in back by loose stitching.
You might also find a couple of tiny tacks in the assembly.
Save any that you remove, a magnet is useful.
The stitching is covered by a flap of the leather.
Lift the flap and
[up to this point you can still just fit everything back together]
snip the -top- of the stitching.
Loosen the top of the stitching enough to
pull out the wood 'shim' that is behind the karda & chakma pockets.
Pull out the rings of leather that form the karda & chakma pockets.
Now is time to tighten everything back together.
[before doing so, read the note below]
Rethread, tighten, and tie as needed to keep everything secure.
If you have excess leather I'd overlap it and tack it down.
I suppose you could glue it with rubber cement or similar---
it's always nice to be able to disassemble things later.
Tiniest brass tacks from the hardware store work fine,
just be sure not to go -into- the blade cavity of the scabbard.
Once the scabbard is again tight,
You'll need to tighten the frog to match.
The frog is held tight by a leather lace that's made to be adjusted.
(Except that sometimes it's made to fit & has no lace
in which case you can: cut it, punch holes, add lace & tighten)
Even if lacing is already present,
you'll probably need to trim it back the front of the frog
& add new holes.
Note: If the frog has nothing to catch onto,
it could slide off the top of the scabbard.
Traditionally, there is a ring of material added
under the leather of the scabbard to act as a stop for the frog.
