Lightweight Variable neck knives
Feedback: +15 / =0 / -0
These two are part of my Variable line of Self Defense Tools. I call this style Brian's Broadhead. This is an extremely versatile design. It is truly ambidexterous in forward or reverse grip. It works well as a push dagger and even in a thumb dagger style. All of these knives carry easily as neck knives, on a static cord or on the belt. I usually carry mine on a static cord or clipped to my belt toward the center of my body.
The first one is carbon fiber. I blunt the very tip of the blade with carbon fiber. I have found that it is very delicate will tend to break off any way. It is still plenty pointy. While CF doesn't develop a durable edge, it does have enough of one to cut. Overall length is just under 4.25" Blade is 2", it is just over .190" thick and the finger hole is 1". $65
The second one is 6al4v titanium. It has the same dimensions except it is approx. .160" thick. It has a carbide edge. $130 PENDING
The third knife is a lower cost version from the others. I normally use D2 or CPM154. This one is 420HC. I came across some and thought I would give it a try. I actually like this steel for this application. This knife has the same dimensions as the others. It's thickness is about .120" 420HC is a fairly good steel. It takes a good edge and will hold it pretty well. For this type of knife, the edge retention isn't as critical as how sharp it will get and it's corrosion resistence. $45 SOLD
Paypal accepted
lovesmoney - It does indeed come with that sheath set up and with neck chain.
Thanks senoBDC. Yes, I will post pics shortly. Have to run a few errands.
Here are 4 shots of various grips, thumb dagger, push dagger, reverse and forward.
I am taking orders for this design and others soon to be posted. I have a batch of the 420HC Broadheads being laser cut and some more at heat treat. Standard price for a higher quality steel Variable Broadhead is $65
Thanks for the kind words!
Hey Dirk
Will you be making anymore of the 6al4v titanium versions? I am interested but seem to be to late for the purchase.
frank
Are any of these still available??? I will be gone for the next week and will not be able to respond till next Friday, but I will take one please!
