My limited experience with lignum is that it doesn't aquire that super hard surface until you let it dry a little while. I think that if you cut out the hole and let the handle set for a while, it should do better as long as you use good epoxy. i have done a couple of lignum handled knives and they seem to be holding up well. On the last one I did, the hole was slightly wider than the tang and the interior was rough, so I probably ended up with a nice little slug of West System epoxy holding on tight to the surface of the wood. I also used a pin.
