I have a like new in box Zebralight SC52 I am throwing in a rechargeable energizer battery.
Selling for SOLD.
(EMAIL ME FOR PICS)
Description
What's New:
Record breaking 280Lm ANSI from one AA Eneloop (more output with Energizer L91 lithium)
Record breaking 3 months runtime at min output (longer runtime with Energizer L91 lithium)
All levels are current regulated.
Battery capacity indicator (LED flashes 1-4 times. 4 short clicks to start)
Low battery alert when the light is switched Off with AA batteries (LED flashes every 80 seconds if the battery voltage is below 1.06V)
Programmable M2 and L2
LED driver circuits sealed completely from the battery chamber
Recessed switch (improved from SC51)
Main Features and Specifications
LED: Cree XM-L Cool White (Norminal CCT 6300K)
User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels or strobes.
Light Output
High: H1 280 Lm (0.9 hrs) or H2 172 Lm (1.7 hrs) / 108 Lm (3 hrs) / 4Hz Strobe
Medium: M1 50 Lm (7.5 hrs) or M2 25 Lm (12 hrs) / 12 Lm (27 hrs)
Low: L1 2.7 Lm (4 days) or L2 0.34 Lm (3 weeks) / 0.06 Lm (2 months) / 0.01 Lm (3 months)
Light output are ANSI out the front values. Runtimes tested (and parasitic drain estimated) with Sanyo 2000mAh Eneloop AA batteries. Light output with 14500 batteries are the same except that the H1 is 500Lm for the first minute and then steps down to 280Lm.
Operating Voltage Range: 0.7V - 4.2V
Battery: One 1.5V AA (NiMH, lithium or alkaline) or 3.7V 14500 Li-ion battery. Batteries are not included in the package.
Parasitic Drain: Negligible (equivalent to 16 years, much less than the self discharging of a battery)
Beam Type
80 degree spill
12 degree hot spot
Dimensions
Diameter: 0.93 inch (23.6 mm)
Length: 3.08 inch (78.2 mm)
Weight
1.4 oz (40 gram)
Features
Automatic stepping down when battery (AA and 14500) capacity is low
Builtin over-discharging protection for 14500 batteries (2.8V cutoff)
Electronic soft-touch switch, with a 200,000 cycle operating life
Smart user interface provides fast and easy access to all brightness levels
Precision machined unibody casing from premium grade Alcoa aluminum bar stocks
Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
Durable natural hard anodized finish (Type III Class I)
Tempered optical grade glass
Preinstalled bezel down pocket clip
Orange peel textured reflector
Anti-roll and tail-standing capable
Battery power can be locked out by slightly unscrewing the tailcap to prevent unwanted activations or parasitic drain
Waterproof to IPX7 (2 meters, 30 minutes)
(Links below so you can read more about it.)
http://www.amazon.com/Zebralight-SC5...m/B00AJXUU6M/2
Pm or email me if interested.
I can add cash or trades depending on what you have.
Selling for SOLD.
(EMAIL ME FOR PICS)
Description
What's New:
Light Output
Beam Type
80 degree spill
12 degree hot spot
Dimensions
Weight
1.4 oz (40 gram)
Features
