Like new Marathon and G-Shock watches
Feedback: +45 / =0 / -0
Hi guys,
I own a lot of watches and these two are getting no wrist time. Both are in excellent condition. I am asking $100 for the G Shock and $150 for the Marathon and that includes tracked shipping in Canada or the U.S. Paypal only and no trades please.
Email is the best way to get a hold of me. Specs and pics are below. Thanks for looking!
CASIO G-SHOCK DW-5600BB-1
SPECIFICATIONS:
Mineral Glass
Shock Resistant
200-meter water resistance
Case / bezel material: Resin
Resin Band
Electro-luminescent backlight
Afterglow
Flash alert
Flashes with buzzer that sounds for alarms, hourly time signals, countdown timer time up alarm
1/100-second stopwatch
Measuring capacity: 00'00"00~59'59"99 (for the first 60 minutes)
1:00'00~23:59'59 (after 60 minutes)
Measuring unit: 1/100 second (for the first 60 minutes)
1 second (after 60 minutes)
Measuring modes: Elapsed time, split time, 1st-2nd place times
Countdown timer
Measuring unit: 1 second
Countdown range: 24 hours
Countdown start time setting range: 1 second to 24 hours (1-second increments, 1-minute increments and 1-hour increments)
Other: Auto-repeat
Multi-function alarm
Hourly time signal
Full auto-calendar (to year 2039)
12/24-hour format
Regular timekeeping: Hour, minute, second, pm, month, date, day
Accuracy: ±15 seconds per month
Approx. battery life: 2 years on CR2016
Size of case/total weight: 48.9 X 42.8 X 13.4 mm/60 g
EL:Blue Green
WATCH. MECHANICAL MILITARY WRISTWATCH. This watch is manufactured by MARATHON WATCH COMPANY. Wristwatch is manufactured in accordance with MIL-PRF-46374G, Type II, Class 4 and this watch has a 17-jewel mechanical movement. The stem-winding mechanism has a minimum 34-hour running time and is accurate to a maximum of +/- 30 seconds a day. Stem for winding and setting time is located at the 3 o'clock position; movement stops when the stem is pulled out.
This watch features a high impact fibreshell case that is waterproof and dustproof. Black military face features both 12 and 24 hour timing with white numerals and a sweep second hand. Luminous hour and minute hands and hour markings are powered by tritium gas filled tubes. This Swiss made watch comes with black nylon mil-spec strap with stainless-steel buckle closure that adjusts to most wrist sizes. The strap is manufactured in accordance with MIL-S-46383B, Type II. Product carries a one-year warranty.
NSN: 6645-00-066-4279 or 6645-01-304-4308 (Ty I, Class 4)
Mechanical, 17 jewel, sweep second
Intended Use: Field
Analogue dial with 2 time scale
Water resistant to 3 ATM (atmospheres)
Stop-second hack movement (movement stops when stem is pulled out)
Non-magnetic and stem-winding mechanism has a 34 hour running time and is accurate to +/- 30 seconds per day.
Fibreshell high impact, waterpoof and dustproof case.
Case diameter 1 5/16 inch or 34mm (without crown)
Black face features both 12- and 24-hour dials, with luminous hands and hour markings, white numerals and a sweep second hand. Luminous features are indicated by self-lighting tritium tubes.
This watch is made in accordance with MIL-PRF-46374G Type II, Class 4
Includes black nylon mil-spec strap with buckle closure that adjusts to most wrist sizes. This strap is manufactured in accordance with MIL-S-46383B, Type II.
