- Mar 7, 2015
I just received my Lil Lionspy - I think it's a really well built knife.
I do have a question, however.
Is the detent supposed to be as WEAK as it is? I backed the pivot off to make it a bit faster so I could "flick" it, and the ultra-weak detent makes that difficult. I can see the detent ball just *barely* falls in the shallow detent well in the blade - like if that detent well was deeper, for better detent ball engagement, that would fix the "problem."
Before I do anything drastic like disassembling and attempting to modify the knife, I want to make sure that this is how it comes from the factory and isn't defective.
I can pretty easily snap the blade out by flicking my wrist with the blade fully closed and only holding the scales (not engaging the thumb hole at all.)
Thanks.
I don't think the detent is really that weak. At least on mine I feel like it more has to do with the fact that the relative positioning of the spyderhole and pivot that doesn't let you build up enough force in your thumb (I assume you're using your thumb) to flick it all the way out before the detent breaks. I can't flick it out with my thumb, but I can spyderflick it very consistently. Makes a satisfying popping when the lock engages too (I think the G10 helps with that).
