dpsmith said:
I just picked up a Lil' Temp leaf blade and have a few questions for all you Spyderco experts.
The experts are all sleeping, I'll see what I can do
dpsmith said:
When was the blade steel switched from CPM 440V to S30V?
The Lil' Temp debuted in the 2002 Catalog(but was likely available in late 2001) and was advertised with 440V, the following catalog(2003) shows the steel changed to S30V, so I would speculate the change took place between the prior to the publishing of the 2003 catalog, likely fall of 2002, or later.
dpsmith said:
Where there more made in CPM 440V then S30V.
Exact production numbers are something Spyderco will not disclose, for reasons of confidentiality(i.e. it shouldn't be public knowledge how much revenue Spyderco made, that type of sales info is, and always should be, confidential).
However, given that the Lil' Temp was advertised with S30V for two years, and 440V for only one year, it stands to reason that there were most likely more made with S30V.
dpsmith said:
How many leaf shape versus trailing point versions were made
See above
And then below for more info.
dpsmith said:
How many years were these made.
Neither myself, nor any of my fellow collectors have EVER seen a Trailing Point made in S30V, so one could assume they were only produced for one year(they were not as popular as the Leaf blade). The Trailing Points are much less common, and if you ever find one with a Serrated Edge, do post it here. An SE Trailing Point is a Unicorn of sorts, noone is sure whether or not they actually exist
dpsmith said:
You're welcome, I hope these answers were of some use to you.
