I'm still in research on my first folder with a lock. I've made a few friction folders, now I'm going to convert that design over to either a liner or frame lock.
For liner lock version I'm going to use 410 steel and Ti if I try the frame lock. I've got a VERY basic setup of tools I've made due with so far (2x42 grinder, dremel, drill press, hand tools).
Cutting materials:
Can I use my dremel with a cutoff wheel to make the lock bar cuts? This is what I planned to do for both lock bars, Ti and steel. I have a cheap hacksaw but can't cut a straight line for my life with it even in annealed carbon steel.
410 Liner Lock:
I'm a bit confused on how the liner lock setup works. Do I bend then heat treat? Can I do the HT to get the spring with a Benzo torch (I don't have a HT oven) or will I need to send out with my blades for professional HT?
Ti Framelock:
If I try Ti, do I just need to mill out enough to allow the lock to naturally bend or does it require HT also?
I know it wouldn't be optimal, but I was going to get a end mill bit and chuck it up in my drill press and go slow, it's what I have to work with... What mill bit would you recommend?
Thanks for your help guys!
John
Cutting materials:
410 Liner Lock:
Ti Framelock:
John
