WaltE99
Fickle Bastard Blades
- Oct 5, 2015
OK, I have a question that's a real head scratcher. Not sure how others do this, but I epoxy liners to handle scales first and let them cure before fitting to them to the tang. Recently I started a set that would have a double liner with one being brass and the other being red fiber. When I began finishing the fronts where they would meet the blade, the brass immediately separated completely from the scale and the fiber is separating from the brass around the edges. I roughed up the brass and wiped everything down with denatured alcohol. I use West Systems epoxy if that makes any difference. What did I do wrong and what is the best way to accomlish this?
Thanks all....
Sent from my SM-T310 using Tapatalk
Thanks all....
