- Oct 3, 1998
Since I've had a lot to say about liner locks, I thought I'd post this excerpt from my Las Vegas Classic review here. I've heard many of the things documented here from other guys also, like Darrel. I'm looking for any interesting comments on the washer sizes, guide pins, etc.
BTW, the blade tang angle Mel used was 7-degrees. What's the general thinking on tang angles among you all? I think a lot of makers use an angle nearer 10 degrees, I wonder if that contributes to spine-pressure failures.
---------- from LV Classic Review -------
Now I've saved the best for last. I stopped by Melvin
Nishiuchi's table. I had never heard of him before, but he had 3
gorgeous liner lock gent's folders on his table. Nice eye for
aesthetics, great workmanship. Now keep in mind as I continue
these were true gent's folders: thin titanium liners, thin
scales, thin drop-point blade. Not an overbuilt tactical -- a
delicate-looking but handsome gent's folder.
Anyway, once Mel sees I'm interested, we start talking about
liner locks. This guys tests his "delicate" gent's folders
harder than I'm willing to test most overbuilt tactical folders;
ironically, the delicate gent's folders pass all the tests!
He started out showing me the huge oversized brass washers he
uses. I soon really came to appreciate these, as they're the
cornerstone to his great linerlock reliability. The washers were
big, extending from the top to bottom of the bolsters, and nearly
front to back. Huge. As you probably know, many liner locks
will fail when you torque the blade. Mel took his little folder
and torqued it so hard I thought the whole thing would fall
apart, but his liner lock held *perfectly*. He explained that
many makers use tiny washers in order to minimize blade-to-washer
friction. However, when you torque the blade, those small
washers act as a fulcrum -- blade tip goes one way, blade spine
the other, and bam your liner lock gives up. With huge washers
holding his blade in place, there's so much support for the blade
that torquing the tip hard does not cause any movement at the
tang, so the lock holds steady.
Then he put pressure on the blade spine. He put on so much
pressure that the thin liner bent to a seemingly impossible
angle. Still, the liner lock held completely firm. His tang
angle was perfect.
Next, he opens the knife, thumbs the lock aside, and starts
torquing and torturing all over again, showing that even with no
lock the fit is *perfect*. Okay, pretty good so far, but then he
does the same thing with the knife halfway and 3/4-way closed.
No lock pressure, just his oversize washers and excellent
bushing-fit holding the blade in the handles perfectly, even
under extreme torque.
We spent a lot of time torquing and twisting his delicate little
gent's folder, but when it was all over the knife was as solid as
when we started. How, I asked, does this knife stay together so
firmly? So he takes the scale off and shows me. There's 2 or 3
screws holding the frame together, standard construction. But
there's also about 5 small pins spaced between the screws, that
he calls guide pins. Liner locks depend on tight tolerances to
really work perfectly, and with just 2 or 3 screws holding it all
together, just taking it apart and putting it back together can
introduce a tiny bit of variance. But with his 5 extra small
pins, the knife goes back together *exactly* the way it came
apart, and even twisting and torquing and torturing the
"delicate" little knife does nothing to introduce any jiggling or
tolerance problems.
Then we talk about proper liner placement on a new folder. He
agrees with me about the placement. When he makes the knife, he
has the liner barely engaging the blade tang. Then, *before* he
puts the knife out on his table, he spends a few minutes breaking
the knife in. So by the time it's ready to be sold, the entire
liner is engaging the blade -- the leftmost part of the liner is
exactly in line with the leftmost part of the tang. This gives
plenty of room for wear for years. As I've been saying, if the
liner lock is constructed correctly, the liner can be way left
and still hold tight. His knives are living proof.
Lastly, we talked about the ball detent. He says at the end of
the movement of the blade into the handle, the ball should suck
the knife into the handle, as if it's got a backspring. Sure
enough, when you close his knife, as the blade is almost closed,
the ball just grabs it and shuts it for you. Then with the knife
closed, he holds the knife by the blade and shakes it lightly,
showing me that the ball detent keeps the blade shut.
Now I've only met Mel this one time and have never done business
with him. But even though his prices are high (though apparently
well worth it), I highly recommend you check him out. And if you
can, stop by his booth. He talked with me, tortured his knives
and took them apart for me, and I had basically just come by to
look. He doesn't know about the internet or this review, so I
have to assume this is the way he treats all his customers who
show a little interest and ask a few questions. He's at
702-438-2327.
Joe
jat@cup.hp.com
[This message has been edited by Joe Talmadge (edited 09 February 1999).]
angle was perfect.
tolerance problems.
702-438-2327.
Joe
jat@cup.hp.com
