http://www.knife-expert.com/liners.txt
read Bernard Levine's article on the liner lock and Michael Walker and how strong a proper made one actually is.
In red. That's awesome. Well said man.Demko has always seemed like a pretty solid guy, and if you watch the tests they appear to measure everything to make things fair as possible. If you watch the linked video he looks first shocked and then pained by the results. They pull another Sebenza new out of the box and try it as well, which removes the whole spine whack test from the equation and just straight to the weight hang.
I mean, I like my Sebenza just fine but I'm not going to pretend that the frame lock on the Sebenza is remotely as reliable as a tri-ad, AXIS, compression, etc. lock, not after seeing it tested.
When the video came out some of the cultists railing against it made it sound like it was CS trying to make CRK look bad, but that never rang true to me for two reasons:
- If you looked at the past tests the comments often included "try the Sebenza" and they took their sweet time getting around to it
- Do the companies really compete anyway? I have a hard time seeing CS trying to woo away customers of Chris Reeve's Ex-Wife's Knives to buy a Code 4 or American Lawman or whatever . . .
if you read the article fully, you'd have seen Michael mentions most makers seem to fail on the important angle that makes it very strong when done right.@jbmonkey I found one limited test and indeed a couple of the liner and frame locks were very strong but in this admittedly small sample the lockbacks averaged better. I am not an engineer but I still think that built to the same level a back lock can be stronger than a liner lock simply because of the way the members are loaded. Although much of their marketing is cringe-worthy Cold Steel has shown that their lock is extremely strong especially considering the low price-point of many of their knives.
Okay, I will. It's always good to correct my misconceptions. However I haven't seen a break test like Cold Steel does that gives me high confidence in these; can you point to any?
Putting extreme testing and misuse aside.@evilgreg I am definitely not saying that a liner or frame lock cannot be made more than adequately strong; rather that for a given grade of materials and general build quality there are lock geometries that are inherently stronger. I haven't watched those CS tests in years but I think their own Tri-Ad lock on knives of similar size/weight held a lot more than that liner lock, which is exactly the point I was trying to make: if you are seeking the strongest lock possible liner/frame lock is at a mechanical disadvantage.
I have the Spyderco Resilience as my only liner lock knife, and it’s pretty solid so far. I am curious about getting frame locks sometime though. What problems have you had with them?I'll be the weird guy out on this: I prefer liner locks over frame locks. I've had more issues with frame locks than liner locks*.
* Except for Emerson liner locks, those have been a total-show in my experience.
