liner locks and exposed blade sections
RLR
This is bugging me, so I'll post. Many liner locks have a spacer only at the back of the handle, between the two scales, leaving an inch or so of blade "exposed" when the knife is closed. Just look at the closed knife upside down and you see the edge peering up at you. Aesthetically, this is great, and for use I have no qualms. BUT... when I throw it in my pocket (I hate clips, by the way), a key, coin, or other tool invariably ends up wedged in there, nicking the blade. This is a minor gripe, I know. However:
1) am I the only one who has this pet peeve?
2) has anyone modified a knife to "close" this opening (between spacer and stop pin)?
3) are there links I haven't found that deal with this?
Thanks. I don't care about scratches and dings in a handle, etc, but in the blade gets my goat
RLR
I don't put anything else in the pocket where my knife is or is clipped to. The only "FOD" I would have to deal with would be pocket lint.
I carry knives with keys and change and whatnot, and have never had anything caught in there. Actuall, I dislike even the partial backspacers on most knives - I prefer a few cylindrical standoffs separating the liners, to allow for easy cleaning.
--JB
e_utopia@hotmail.com
[This message has been edited by e_utopia (edited 10-02-2000).]
A strip of grip tape should fix your problem and also provide a little traction to inprove your grip on the knife.
My AFCK brings a quarter with it sometimes, when I pull it out.
It is a very minor gripe though.
You're not using a clip are you?
Clipping to pocket usually keeps the knife above most of the junk that's in there unless you have a real long knife or real short pockets
RLR:
Some knives were actually designed with an open back in mind,if you will notice quite a few tacticals are built in this fashion due to the ease of mantience in the field.
As far as colseing that void I have done it on a production Emerson CQC7 with black canvis micarta,with the proper tools is a rather simple task, the hardest part came when I had to drill and tap 2 new holes to support the extended back spacer but all in all the extra work payed off in attractive closed back CQC7, another by-product of this modification was a more rigid less flex feel during hard use.
Kevin
[This message has been edited by K Robinson (edited 10-02-2000).]
If ya' carried an MT SOCOM, you wouldn't have this problem. There are only little slits down the back for ventilation or something, and they are about 6mm long and really thin.
Chang the Asian Janitorial Apparatus
Its a sore point for me also. Coins will dull the blade. Spacers protect the blade. Its especially poor design on a small folder that is likely to go clipless in the pocket such as an Unfaam (sp) or William Henry. No excuse, it should not need a case although its more a design flaw in the frame lock.
Roger Blake
Great to see I'm not alone, maybe outnumbered, but not alone.
I could change knives, use a clip, not carry anything in my pockets, but at the end of the day, I'd still throw a folder in with some junk and ding, ding, ding... I think minor alteration is in order here.
Thanks and cheers,
RLR
David,
Frank Recupero could probably make that happen for you. I believe he posts here as "ats34". Or you can just check out his site:
http://members.nbci.com/ats34/
(Be patient, it takes about 3 days for his site to load
Semper Fi
-Bill
Originally posted by Bronco:
David,
Thanks for the link (BTW the site loaded in about 10 seconds..) but I think I could do it by myself. Only if I could find some small cylinders....
David
DIVERTI NESCIO
My Photopoint pictures
Mikov Knives
Visit our region
I really like my knives to be "open." I think it makes them much easier to clean. I try not to keep coins or keys in the same pocket as the knife anyway, because I don't want to have to be fishing through a lot of junk in my pockets to get to the knife.
Just my humble opinion.
~Mitch
My Hobby Page
David,
Catalog 2000/2001. Part # SF01. Bottom of right column. No dimensions listed.
Chi
[This message has been edited by CK (edited 10-06-2000).]
Originally posted by CK:
David,
Chi
Hmmm... I just discovered that I had the 1999/2000 catalog - no part number SF01
. Could you at least tell me the page #? I will try to download the appropriate part of their catalog. Thanks
David
DIVERTI NESCIO
Mikov Knives
Visit our region
David,
I just gave my mini-Stryker the full treatment; anodized & fileworked liners, natural linen Micarta scales and replaced the backspacer with those nice little round spacers. What I used, and found worked great, was nothing more than your standard 3/16" pivot pins. The ease of the mod was well worth the extra cost of the pins ($2.50 apiece). The barrels and screws were easily shortened to the exact length needed for the blade to function properly. The back of the knife is completely open except for the two spacers and the stop pin. Looks a lot better than stock and performs better as well (miraculously, the blade is perfectly centered and stays there now). Will post a picture tomorrow David so you can see how it looks. Really a very simple process to replace the spacer and the price is right as well.
