- Mar 2, 2006
Has this ever happened to any of you while using a linerlock for bushcraft?
http://www.bladeforums.com/forums/showthread.php?t=540445
Its hard to justify pushing a folder IMO.
And let's not forget the difference between a lock failing due to structural weaknesses, and design failure, by which I mean "how easily the lock can be accidentally disengaged."
This is what I find when I use a Liner Lock.
I have found that the Lock Failures that have happened to me is, I have a strong grip that can on some frames flex enough to make the lock disengage.
This does not happen with frame locks though. With this kind of lock i find that my finger holds the lock in position.
I have never personally had a quality-made liner lock close on me that way during bushcraft use. More often, I've had thin titanium or other flexible metal liners bend -- flex__ and cause the lock to disengage that way. I tend not to twist the blades in the way that may happen in a self-defense situation, though. My larger folder, which I have used extensively and hard in real-world field conditions, has a stainless steel liner, and has never once come close to fialure in any way. I won't buy a liner lock of any type unless it has a steel liner now.
