You can, but it wouldn't be a good idea.
Normalizing (at higher temperatures than for carbon steels) would put into solution all the carbon, and air cooling would redistribute the carbides in a fine state.
Problem is that ledeburitic steels have so much alloy elements that for dissolving you would approach melting temperatures. That is why huge carbides forms already in the melt and won't move at lower temps.
Powder steels have been developed to allow a fine setup of those high volume carbides, but normally even a traditional process and good mill's job keeps them at bay good enough to work with.
If big lumps of carbides are the result of an error at the mill or during ht you let the carbides coalesce into big lumps there is little to do to erase the situation but change the steel batch. Generally big carbides tend to get bigger at the expense of smaller ones, and are the least to dissolve.
