- Oct 30, 2002
Well, my forge is here (an Ellis 8HT horizontal forge), but I'm missing a box that I'm assuming has the ITC-100 and the lining instructions. As it is, I have the kaowool, satanite, and some Mizzou (for the floor, I'm assuming).
As I have a free weekend, I'd like to get started on it, but with the Ellis' away from the shop for the holiday, I need some guidance.
My thoughts are that I need to cut a single layer of kaowool (about an inch+ thick) to line the forge body and the end caps and cup out the openings for the front and back as well as for the burner and TC.
Next, I'm thinking a 1/4" layer of satanite over all of the exposed kaowool.
Any good instructions on mixing up the satanite? I've got a two pound bag. Do I need to mix all of that up to a plaster? After I've got the satanite applied, I'll let it dry before applying the ITC-100 (when I finally get that in).
And as for the mizzou, I'm assuming that is for the forge floor. Should it be laid last, or should it also be ITC-100 coated?
Having never done this before, I'd appreciate a little guidance from the many of you who have done this many times. Thanks!
--nathan
--nathan
