- Sep 5, 2006
I've got them both and the lionsteel opens way slower.
Worse steel? How so? The Sleipner steel is pretty good stuff.
Another construction point to consider is that the Lion Steel uses teflon washers and LS doesn't recommend using phosphorus bronze washers because they have found that the pb washers bind. I have two of the LS knives and haven't noticed that the teflon washers are a negative, but I would prefer pb washers on a knife of this price point. My ZT's have pb washers. I also have to wonder if the use of the more flexible/pliable teflon washers are in use because the LS knife does not have the exacting tolerances required to use the pb washers. That being said, I like both, and my wife carries the LS and I carry the ZTs.
I have about ten Zero Tolerance safe queens and they are exceptionally high quality. I owned two Lionsteels several months ago and returned them due to a couple issues. (I had an SR1 and SR2 as I recall.) First, the blade tip extended too far down the scale. You could feel the blade tip while gently rubbing your finger over the bottom of the scales. Second, the liner lock was very difficult to open on both. Very stiff. The LS knives were certainly beautiful and were high quality except for the above issues. Among the ZT’s I own are the 0393, 0350bw, 0770cf, 0562cf, 0452cf, 0801bw, 0801ti, 0460cf . . . and my favorite is the the 0393. Just a wonderful knife. The only ZT I don’t recommend is the 0566cf (mine is hard to open as the lock sticks like the LS’s I mentioned.) Also, the assisted opening on the 0566cf is not as smooth as the 0770cf and 0350bw. You can tell I’m a big fan of ZT knives.I've got them both and the lionsteel opens way slower.
If you knew me you wouldn’t be surprised! Have a good day!You must be since you just replied to a 4.5 year old thread![]()
