A Boye Prophet Companion was my first pocket clip folder, a gift from my wife after graduation. After about 2 years of hard use and almost daily metal removal sharpening, I finally wore it out. Actually, it would still work, but the edge was about 1/8" back from its original location. Only at this point did I start using diamond stones on it. I used a 325 grit DMT (blue) to reprofile it, with no ill effects. To my surprise, the edge also did not chip, despite the rough treatment I gave it. I kept it sharp enough to shave strips from annealed steel wire (tie wire for rebar) and this didnt seem to dull it after 2-3 strips. I used nearly everything to sharpen this knife, from $5 AO stones, to DMT, to 80 grit belt on a 1x30 sander. If I can sharpen it with that, then there is no need to worry about diamonds cutting too fast. I used an Arkansas stone for a while, but found that it cut too slowly.
The point is, I like this knife alot, and all the above methods gave good edges. I believe the Edge Pro uses water stones. I just recently started using water stones, but if there is a stone in the 600-800 grit range for the edge pro, that should work fine. My 800 grit stone gives my kitchen knives an aggressive edge that will shave hair with a slicing motion (not recommended, but I havent cut myself yet).
The stated purpose by the maker for using a cast steel is that the carbides (presumably Chromium Carbide) that form are fairly large and are quite aggressive. It's probably safe to assume they are fairly evenly distributed, although finer carbides in the same volume amount would be more so. I read somewhere (I think it was from Cliff) that occasionally, an abrasive should be used that will cut the carbides, ohterwise there will be dull carbides along the edge of an otherwise sharp blade. If the sharpening abrasive wont cut them, then they will just become rounded and will tear out as the steel around them is worn away. This is why every so often I used my DMT or some SiC sandpaper on my 440V Random Task, just to sharpen the carbides and get some good bite from them.
