- Jun 24, 2013
I have no clue how they are supposed to look but I like what you created.
Well, the bunch of originals, that I have all have heavy points, as that was sort of the point (pun intended).The 1796 LC sword doesn't have a heavy point. It has a wide but very thin point (usually under 2mm). It's like a thin kitchen knife with a 30" handle (part of which is sharp).
Most swords that widen at the tip have very thin tips (originals, anyway - replicas are a different story). Seen in profile, the width suggests extra weight, but the cross-section says otherwise.
BUT that is a debate for another thread, as this thread is about a custom sword of quite another type, so lets cut that tangent short now (yes, I brought it up in passing, I know).
I think we can probably agree on a fairly forward POB feeling like a heavy point-this sword balances @ maybe 1/3 of the OAL from the pommel, which certainly registers in the hand as point heavy.
1/3 of OAL from pommel is the classic jian POB/COB/COG (the POP/COP will be placed differently, close to the tip). I like light-hilted swords. It does push the POB out from the guard, which makes it feel point-heavy when held stationary. But the moment of inertia about the grip is lower than the same blade with a heavier hilt or pommel, so dynamically not point-heavy. Light hilt -> lighter overall and a little more agile in the cut. What's not to like about that?
Thanks. The karabela isn't a pommeled sword-slab grips and (on fancier non-munition grade swords) a metal band around the edge of the grip:I applaud the efforts, and the choice. I cut my fullers in cold, too. I use a die grinder with a brazing rod hose-clamped to it, and the rod is bent to serve as a finger for the grinder to follow the spine. I also should mention that it is a variable speed die grinder, so I can cut and smooth pretty well with it.
I didn't see a pommel on the first sword, did I misinterpret the pic?
Having essentially no experience with originals of these, I don't know how the curve is supposed to be shaped along the length of the blade, or the distal taper. I can say that the information on distal taper that horseclover is giving you is spot on for messers and for daos.
great work. great choice, too.
