I’ve done cryo on hundreds of steel coupons and never cracked one but I suppose it could happen. San-mai steel is most prone to cracking.Less chance of cracking! Precisely what a knifemaker that I respect told me once, that’s why he prefers to use high temper to remove RA.
So, there’s not a real difference between dipping the blades in liquid nitrogen and slowly let the blade achieve that temperature, Larrin? I mean, toughness wise?Here are papers that looked at the effect of cooling rate though most/all are behind pay walls. Like other cryo studies I don’t see any clear trend to rely on based on these studies and at least one of them admits that the effect size was extremely small if there even was one. The benefit of wear resistance testing is that it is highly variable so they can find trends in the data.
Only one of the studies looked at toughness. A "direct soak" at -73°C led to a small improvement in toughness vs no cold treatment though it also showed a small reduction in strength. The study claims that a 3°C/s cooling rate led to the best toughness and strength. Either the reduction in strength was a fluke or this was due to interactions with the high temper, where in come cases cryo shifts the peak strength tempering range. That is one of the difficulties of these cryo studies is they will use different steels and different base heat treatments and often don't vary the austenitizing and tempering temperatures. When they do, they typically conclude that the austenitizing and tempering temperatures had a much bigger effect than the cryo variables. In the same study they found that a 1°C/s cooling rate led to a reduction in both strength and toughness, so even if we buy the results of the study, it wouldn't clearly show that slower is always better, but would paint a more complex picture that you must optimize the cooling rate based on steel and heat treatment.So, there’s not a real difference between dipping the blades in liquid nitrogen and slowly let the blade achieve that temperature, Larrin? I mean, toughness wise?
Nothing very scientific, cut and chopping tests so far. My edges are ground thinner, convexed, and have just held up betterHow you testing ?
Your good man. I’m not worried about it. My results basically speak for themselves. So I don’t get offended. The only thing that bothers me is when others that have never tested or heat treated weigh in and and try to criticize our work! Not you. You understand and work with us on heat treat and contribute to Larrins research!!Again,rodriguezryan14 , I apologize for referring that slowly cooling could be better than directly dipping the blade in LN. Larrin cleared this.
I ask because I play with 52100 steel and I found that it is hard to get some data/conclusion with tests like that ..it is difficult to notice the difference .Nothing very scientific, cut and chopping tests so far. My edges are ground thinner, convexed, and have just held up better
Yes I do. I’m primarily working with A8 mod right now. That’s basically infi. My blades range from 59-60 rc on average! I’ve had a couple come out in the 58 range with no cryo and high temper! I have 52100 on hand, just haven’t got around to heat treating any of it! I’ll eventually experiment with it in the future. I find A8 mod to be more than good enough for a lot of different blades right nowI ask because I play with 52100 steel and I found that it is hard to get some data/conclusion with tests like that ..it is difficult to notice the difference .
Do you have a Rockwell tester?
a knife is the sum of its parts, and while it's interesting and informative to go into the weeds of heat treating, there are many factors which can make for a bad knife even if it's heat treated perfectly. When it comes to the performance of the blade itself, physical dimensions play a much bigger role, in my view, than whether its heat treatment is 'good enough' or 'the best'. I personally strive for the best, but understand that is probably not going to be my result the majority of the time.
don't get me wrong, I do try and be meticulous when it comes to how I run my heat treating, and am open to learning as much as my brain can absorb about it and adopt better methodology whenever possible, but.... there are many variables outside my control. The temperature of my shop being one- that'll affect all sorts of things in small ways. A minute here, a minute there. How many knives are going through the process at any given time. How warm my quench plates get. Of course there are ways of mitigating a lot of variability, but my feeling is that the results are probably not significant compared to many other aspects of a knife's design.
if a maker chooses the right material for the job, has a digital kiln, preps their work properly, follows a proven protocol and makes informed adjustments taking into consideration the dimensions of the knife they're making and its intended use, then I think their patrons/customers will be pleased with the outcome of the heat treatment. Even if it's not perfect. If perfect was what people were looking for when buying handmade knives, there would be very few humans involved in the making of them.
as for the idea that slowly freezing a knife is better than quickly freezing it, well it just doesn't make sense to me. When I think of quenching, I think of something that happens at speed. Freezing a knife is part of the quench, in my mind, so to me it makes sense to get that done quick as possible. Now, I don't know much about this stuff, but I feel like LN2 is superior to a dry ice or deep freeze because it acts on the steel faster, not just because it ultimately gets the steel colder
In Larrin's book on page 289 he has a chart for RA with T1 and aging time. If the steel reaches cryo tempterure within an hour the increase in RA is less than 1 percent
He gives another example after, of w1 which after aging at room temp an hour, ends up having a bigger increase in retained austenite than the t1. And explains that the carbon in solution being higher than in the high speed steel, caused more stabilization of austenite in that ammount of time.In Larrin's book on page 289 he has a chart for RA with T1 and aging time. If the steel reaches cryo tempterure within an hour the increase in RA is less than 1 percent.
read this alsoI have the book, looks like i have some more reading to do
Yeah. I'm sure thats more than fast enough for liquid nitrogen.Blankblank Even the W1 charts are showing less then 1 percent RA gain from immediate cryo to cooled within the hour.
For me it is about 6 minutes from plate quench to cryo dewar. I let the blank sit in the plates for a minute or so and then put the clamped plates in a five gallon bucket of ice water for a couple minutes then the ice water cooled blank into the cryo.
