I was wondering if any Sebenzas have been returned for blade play due to wear between the area of the blade tang and the surface of the liner that makes contactn with the blade? If so, would it be possible to purchase a lock side scale from you?
This is not something we have experienced because of "wear" - it can happen for some other reasons - after market modifications or screws not being tight or dirt in the lock or similar things.
We would not send out a lock side scale (or blade or other knife parts!) - we would ask that the knife be returned to us so that we can put right whatever it is that is not correct.(There may well be a charge for the repair, however and we would be in touch with the customer about it.) Part of what you get when you buy a Chris Reeve Knife is "service". It is important to us that the knives work the way they were intended and we will gladly work on any knife that needs it.
- Anne Reeve, 10/09/98
Just to clarify a point here, the pivot pin on the Sebenza is not asymetrical and is also not the part that you are thinking of in terms of rotation! The stop sleeve, against which the blade rests when the knife is open, can be rotated it necessary to get just a tiny bit of take-up.
If you go to our website at
www.chrisreeve.com you will see detailed diagrams showing the relationship between the blade and pivot, the stop sleeve and the lock.
Lateral movement in the blade is not acceptable in a Sebenza. If there is play, there is something wrong and the best thing to do would be to send it to us so we can put it right.
- Chris and Anne Reeve, 10/09/98
My problem is that the lock travels and hits the opposing liner when a firm grip is applied. I disassembled it and cleaned it thoroughly but the problem persists.
There is nothing to fix!! The lock will move over toward the back of the front handle slab if you press hard on it. After all, it is a spring that has a natural position and can move further if pushed. The spec position for the lock is to cover 75% of the blade. If it falls naturally further than that, we will adjust it.
A difference between the Sebenza and other liner locks is that you can get in behind the lock of a Sebenza and push it over. With the others, you can only push from the top of the liner which is a less effective movement.
We know that a lot of owners of Sebenzas like to adjust the lock and the pivot etc. but we DO discourage this. When we ship the knives, they work the way they are intended and modifications usually end up with something not working right!
- Anne Reeve, 11/03/98
